What's the difference between LS exhaust and Type R catback exhaust?
Old Nov 30, 2004 | 01:33 PM
mikey1987's Avatar
Default What's the difference between LS exhaust and Type R catback exhaust?
are they interchangeable? what's different?
Old Dec 1, 2004 | 08:37 AM
andrew dc's Avatar
Default Re: What's the difference between LS exhaust and Type R catback exhaust? (mikey1987)
the itr is slightly bigger. they are interchangable, just don't buy the jdm one since it uses a shorter cat.
The tip is also different.
Old Dec 1, 2004 | 11:10 AM
Miss PSI's Avatar
I have an itr exhaust on my LS and I love it.. has a very nice sound to it... yes they are interchangeable....
Old Dec 1, 2004 | 11:30 AM
timmy8151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikey1987 &raquo;</TD></TR><TR><TD CLASS="quote">are they interchangeable? what's different?</TD></TR></TABLE>
The LS exhaust has a ~1.86" diameter piping, while the ITR has 2.25" piping. Also, the ITR muffler is supposed have more flow and also has a slanted, welded tip.
As posted above, it's a direct bolt on to 94-99 LS/GS/SEs and 00-01 GSR's. For 94-99 GSR's the b-pipe will need to be extended ~ 4.5"
Old Dec 1, 2004 | 05:18 PM
mikey1987's Avatar
Default Re: What's the difference between LS exhaust and Type R catback exhaust? (timmy8151)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">The LS exhaust has a ~1.86" diameter piping, while the ITR has 2.25" piping. Also, the ITR muffler is supposed have more flow and also has a slanted, welded tip.
As posted above, it's a direct bolt on to 94-99 LS/GS/SEs and 00-01 GSR's. For 94-99 GSR's the b-pipe will need to be extended ~ 4.5"</TD></TR></TABLE>
ahh, so i'll loose backpressure but will the car still sound as good? i know there would be no sound of the VTEC kicking in but, if i could get intake and exhaust, slap those on to make the car fun for awhile, and tehn when i do the motor swap it'll be all ready.
Old Dec 1, 2004 | 05:23 PM
timmy8151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikey1987 &raquo;</TD></TR><TR><TD CLASS="quote">ahh, so i'll loose backpressure but will the car still sound as good? i know there would be no sound of the VTEC kicking in but, if i could get intake and exhaust, slap those on to make the car fun for awhile, and tehn when i do the motor swap it'll be all ready.</TD></TR></TABLE>
The ITR catback sounds pretty much stock, except at WOT, where it's louder than the LS catback. I chose the ITR setup mainly because of its quiet sound and its increased flow.
Old Dec 1, 2004 | 05:24 PM
mikey1987's Avatar
damn - wait a sec. i was talkin about the aftermarket stuff, like would an aftermarket Type R catback fit a stock LS.
i guess it would though, jsut by the transitive property, and common sense. i never really made that clear in the post, my bad
Old Dec 1, 2004 | 05:52 PM
dFreezy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikey1987 &raquo;</TD></TR><TR><TD CLASS="quote">damn - wait a sec. i was talkin about the aftermarket stuff, like would an aftermarket Type R catback fit a stock LS.
i guess it would though, jsut by the transitive property, and common sense. i never really made that clear in the post, my bad</TD></TR></TABLE>
in terms of fitment of aftermarket exhausts, there is no difference between ones made to fit type r's, 94-01 non-vtec's, or 00-01 gsr's; they're all interchangeable. exhausts made for 94-99 gsr's are not.
Old Dec 8, 2004 | 07:47 PM
JMigs's Avatar
Default Re: What's the difference between LS exhaust and Type R catback exhaust? (dFreezy)
so to bring this back up from the dead.....
My 94ls that I just got has the ITR exhaust. However, it has no cat and has a test pipe. It makes a horrible noise between 3-4k rpm and is just aggrivating. I need either a resonator or a cat. converter. My question is would a stock LS cat do the trick? This is also mating up w/ a Megan Racing header. I know the ITR is 2.25" but I'm not sure if a stock cat will work....or some sort of resonator for that matter.
Old Dec 8, 2004 | 11:41 PM
Calsonic's Avatar
Default Re: What's the difference between LS exhaust and Type R catback exhaust? (JMigs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMigs &raquo;</TD></TR><TR><TD CLASS="quote">so to bring this back up from the dead.....
My 94ls that I just got has the ITR exhaust. However, it has no cat and has a test pipe. It makes a horrible noise between 3-4k rpm and is just aggrivating. I need either a resonator or a cat. converter. My question is would a stock LS cat do the trick? This is also mating up w/ a Megan Racing header. I know the ITR is 2.25" but I'm not sure if a stock cat will work....or some sort of resonator for that matter. </TD></TR></TABLE>
Using the stock LS cat will create a bottleneck.
Old Dec 9, 2004 | 12:38 AM
milano2kdc2's Avatar
assuming that your megan header has a 2.25" - 2.5" collector, adding a LS cat would not only create a horrible bottleneck, but also a exhaust leak beucase the collector of the header is bigger than the inlet of the cat. so you'll end up with a very annoying ricey sputtering noise.
Old Dec 9, 2004 | 05:42 AM
gmrnguyen's Avatar
how come the 94-99 gsr exhaust aren't interchangeable with the 00-01 gsr?
Old Dec 9, 2004 | 05:44 AM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
Default Re: (gmrnguyen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gmrnguyen &raquo;</TD></TR><TR><TD CLASS="quote">how come the 94-99 gsr exhaust aren't interchangeable with the 00-01 gsr?</TD></TR></TABLE>
The B pipe is about 4.25 inches too short. It's stated above.
Old Dec 9, 2004 | 05:46 AM
dFreezy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gmrnguyen &raquo;</TD></TR><TR><TD CLASS="quote">how come the 94-99 gsr exhaust aren't interchangeable with the 00-01 gsr?</TD></TR></TABLE>the cats and b-pipes are different lengths. the 94-99 gsr's have a shorter cat and longer b-pipe and the 00-01 gsr's have a longer cat and shorter b-pipe. the difference is about 4.5 inches.
Old Dec 9, 2004 | 04:03 PM
JMigs's Avatar
Default Re: What's the difference between LS exhaust and Type R catback exhaust? (milano2kdc2)
so...we're looking at an after market 2.5" cat, correct? I'm having trouble seeing what the deal is here since the ITR exhaust is 2.25....of course I could just be extremely stupid. Basically I'm just wondering the exact size I need here...whether a stock one of some sort will work, or aftermarket.
&lt;-----apologizing for the newb-ness
Old Dec 9, 2004 | 04:17 PM
LSvtec03's Avatar
the ls b pipe also has different bends than the type r
Old Dec 9, 2004 | 06:29 PM
JMigs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milano2kdc2 &raquo;</TD></TR><TR><TD CLASS="quote">
assuming that your megan header has a 2.25" - 2.5" collector, adding a LS cat would not only create a horrible bottleneck, but also a exhaust leak beucase the collector of the header is bigger than the inlet of the cat. so you'll end up with a very annoying ricey sputtering noise.</TD></TR></TABLE>
Yeah, that's the noise I'm dealing with now from 3-4k rpm's. It sounds excellent after that. I just need to know what I'm looking at needing to get for this cat and/or resonator for this exhaust. From the cat back is the itr exhaust, it's just that test pipe in b/t that and the header collector that's causing the problem.
Old Dec 9, 2004 | 06:34 PM
pbizzlegsr's Avatar
a little off topic but on a 94-99 gsr with a jdm itr header..what length cat would be needed? would a jdm cat length be needed?.. being that the oe catback is used
lPat
Oct 5, 2007 02:04 PM
jrzy2nR
Jan 14, 2006 06:35 PM
Grandprix
Mar 1, 2004 05:51 PM
InTeGrA_bLazEd
Oct 3, 2003 05:08 PM
vtecsoldseperately
Aug 16, 2003 04:11 PM
