OBD1 to OBD2
Old Dec 30, 2001 | 11:10 PM
Patron's Avatar
Default OBD1 to OBD2
how difficult would it be to switch obdI to obdII. what would i need to do to drop a '98 ls motor into a '95 civic? thanks
Old Dec 31, 2001 | 09:56 AM
3.3.3's Avatar
Default Re: OBD1 to OBD2 (ptran13)
jumper ecu cables
Old Dec 31, 2001 | 10:26 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: OBD1 to OBD2 (maks)
Got a jumper harness if you're interested e-mail me or IM me
Old Dec 31, 2001 | 10:27 AM
B_CRUZ!'s Avatar
why would you wanna make a OBD-1 car a OBd-2? use a 1998 Ls motor BUT use 94-95 Ls injectors, 94-95 Ls distributer, your stock 1995 civic harness and a 1994-1995 Ls ecu.
Old Dec 31, 2001 | 10:31 AM
Spade's Avatar
Default Re: OBD1 to OBD2 (initial_B)
Exactly, and you didn't post this in every damn section, you probably would have found which one has an answer by now!!!
Old Dec 31, 2001 | 10:33 AM
kenji's Avatar
25 Year Member
initial_B
There is no need to do all of that. All you need to do is drop the OBD2 LS motor in and plug it up and plug in an OBD1 ECU. I have done this swap many times before...
But, if anybody needs an OBD1 to OBD2 ECU conversion harness I can make that. Email me at kenji211@gte.net
-kenji
Old Jan 2, 2002 | 02:43 PM
B_CRUZ!'s Avatar
Default Re: OBD1 to OBD2 (kenji)
kenji what about the distributer plugs? aren't thery totally different? same with the fuel injectors?
jthrasher1
Nov 19, 2010 06:41 PM
dndn
Mar 21, 2009 10:56 AM
ddong2lee
Jul 22, 2003 06:03 AM
gsr squirrel
Oct 8, 2002 03:59 PM
Patron
Jan 2, 2002 05:51 AM
