4x114 brake conversion
ok...heres the deal...im looking into doing the itr 4x114 brake conversion on my 95LS....the only Q i have is, can i just buy the 4 spindles w/hub rotors and calipers and the rear trailing arms?? would i be able to hook up my stock brake lines and E brake cable to these??? I know somebody selling just these parts...would i be able to use them with the rest of my stock brake setup?? any imput would be appreciated....thanks guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marsbike »</TD></TR><TR><TD CLASS="quote">aren't the integras 4X100?</TD></TR></TABLE>
The 97R is 4x114, I believe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeGmAn18 »</TD></TR><TR><TD CLASS="quote">y would u wanna do that just wondering.....do the five lug or you cant?</TD></TR></TABLE>
i have the chance to do this conversion for very cheap...and it allows me to choose from diff rims..i mean i already have 4x100....why not get 4x114 for like 100 bucks ro so....i could swap them whenever...depending on my wheel mood
From: Salt Lake City, Chicago at heart, UT or IL, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95LSDOHC »</TD></TR><TR><TD CLASS="quote">i have the chance to do this conversion for very cheap...and it allows me to choose from diff rims..i mean i already have 4x100....why not get 4x114 for like 100 bucks ro so....i could swap them whenever...depending on my wheel mood
wtf?
</TD></TR></TABLE>wtf?
wtf?</TD></TR></TABLE>
what dont u get?? i have 4x100 now like all usdm tegs(except itr)....i have the chance to change to 4x114 for dirt cheap...i just wanna know if i can do it with the parts i listed at the top....and still keep the rest of my stock brake setup?? I mostly wanna do the conversion so i can have a more broad choice of rims...because most of the rims ive been looking into are mostly 4x114....hope i was more clear
The 4x114 is the size from the prelude 93 and up, it makes very good sense to do this swap because it would bring you that huge *** caliper and 1 inch bigger rotor that is the same size as the itr wich brakes from 60 in 116ft as aposed to non itr wich brakes from 60 in 140ft, big *** difference.And as a bonus there are more wheel options.
I do not know if the spindles would bolt right up but you could add the calipers and rotors by bolting up the calipers and having the rotors redrill to 4x100 and get the braking increase. minimum 15 wheel then
As far as i know all ITR's are 5lug.
Even if the brakes will work how will this affect the offset of the rims. Something else to look into. Would suck to swap eveything and then have bad handling because of the offset.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TruPerformance »</TD></TR><TR><TD CLASS="quote">all ITR's are 5 lug. Doesn't matter what year.</TD></TR></TABLE>
actually not all ITR's are 5 lug noob
Yup, not all of the R's were 5-lug. The 96Spec R was a 4X114. Sorry, I can't give any information beyond that, but you will get all of the info needed from the Type-R forum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech »</TD></TR><TR><TD CLASS="quote">Ok so all USDM ITR's are 5 lug......right????
Yes and yes.
</TD></TR></TABLE>Yes and yes.
but isnt it a bitch to find replacement rotors and pads for the 4x114 set up..
i was reading in the ITR forum that the 1 guy that did had a hell of a time finding replacement parts let alone aftermarket stuff..
correct me if i am wrong b/c i have been looking into this suspensoin swap but the whole replacing things when worn out seems to be quite a hassel and if i but it used i would want to replace it b4 i installed it on my car..
any imput is greatly appreciatted
thanks
thanks
you can order re-drilled rotors from fastbrakes.com and itr wheel offset is the same as all other integras. accord calipers work as due prelude and legend calipers one of the legend models and the accord wagaon even have 2 piston calipers said to be made by brembo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ssdjoey1904 »</TD></TR><TR><TD CLASS="quote">you can also get the dope *** old skool wheels that the ae86s use which are 100 times better than 4x100 and cheaper</TD></TR></TABLE>
this is why i wanna do this conversion....most of the dope jdm rims i like are 4x114....for the price it is...im prob just gonna get it, deal with any problems down the road
