Poping noise when i open my door??? Pics inside
Old Nov 30, 2004 | 12:09 PM
90 Si Hatch's Avatar
Default Poping noise when i open my door??? Pics inside
well when i open my door i hear a poping noise and it gets on my nerves here is a pic from where its coming from. so what do i need to do to fix this a friend of mine his CRX Si did the same thing. so if any one could help me out with this it would be great.
kaoss_11's Avatar
B A N N E D
I would asume thats the problem
Old Nov 30, 2004 | 12:10 PM
goforbroke's Avatar
MEAT PATTY
Default Re: Poping noise when i open my door??? Pics inside (White90SiHatch)
My buddy works at a body shop and he said that is common problems on our EF's. You have to replace the bracket, thats all.
Old Nov 30, 2004 | 12:11 PM
Default Re: Poping noise when i open my door??? Pics inside (goforbroke)
is it something that just comes loose?
Old Nov 30, 2004 | 12:13 PM
ICeDoUt's Avatar
mine does that too, i am eventually gonna get around to welding that lil thing to the sheet metal and see if it stops.
Old Nov 30, 2004 | 12:39 PM
aaronhume's Avatar
Default Re: Poping noise when i open my door??? Pics inside (ICeDoUt)
ya I have a similar problem but I have to get the bracket welded back in cuz it broke enough metal out of the way
Old Nov 30, 2004 | 12:46 PM
RCautoworks's Avatar
The hatchback in the family has the same problem, but it actually is breaking off from the body, I need to reweld it and it will be fixed.
Old Nov 30, 2004 | 01:10 PM
Default Re: Poping noise when i open my door??? Pics inside (90blackcrx)
so there isn't a stud under the finder i could tigten up or something?
Old Nov 30, 2004 | 01:39 PM
Yours don't look broke yet, the one on my hatch looks to be rewelded and welded again because it cracked part of the metal.
Old Nov 30, 2004 | 01:44 PM
tolnep's Avatar
People post on this ever so often. Do a search. The problem is the thing that comes out of the finder area that the door stop/holder attaches to. I breaks off inside an inclosed area that you cant get too (at least I have done searches and there is no solution that is easy). I think that when the car was assembled, that thing was spot welded to the frame. You an see the area to the right of the tab itself that looks kind of like a V. So it doesn't bolt on, it was attached and then spot welded. Down inside that area it breaks off in one or two places and stays attached enough to spring-pop everytime you open the door. It bangs back against one side of the slot. Every solution I have heard was done by some welding genious with no detailed procedures. Guy would say 'friend is a master welder, I showed it to him and he fixed it in 10 minutes'.
If someone has a real fix for this I would love to know. Please no crazy glue or other lame solutions.
IS VERY COMMON. Like having your teeth fall out if you just live long enough...
Old Nov 30, 2004 | 02:54 PM
kid-honda's Avatar
None of mine have this but its common and once it happens there is no "permenent" fix you just need to reweld everytime.
I suppose if you really wanted you could cut that section out and replace it with a section off a other car if you really wanted to be picky.
Old Nov 30, 2004 | 03:48 PM
mrtoastyjr's Avatar
Default Re: (kid-honda)
did any of you try white lith. grease?
Old Nov 30, 2004 | 04:13 PM
CRX_1.8T's Avatar
Default Re: (mrtoastyjr)
I just marinated that piece in all-purpose automotive grease and it stopped making noises.
Old Nov 30, 2004 | 04:16 PM
Dwight Schrute's Avatar
Default Re: (CRX_1.8T)
there is a spring back there too, i could see it popping on my friends car. on my old crx the pin that goes throught he hinge would pop up and down.
Old Nov 30, 2004 | 07:00 PM
CRX_Control's Avatar
Default Re: (drewthomas14)
i found a poping sound comming from my door, i found out that my fender was rubbing the door and made the sound haha. fixed it by bumping out the fender
Old Nov 30, 2004 | 07:36 PM
tolnep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda &raquo;</TD></TR><TR><TD CLASS="quote">None of mine have this but its common and once it happens there is no "permenent" fix you just need to reweld everytime.
I suppose if you really wanted you could cut that section out and replace it with a section off a other car if you really wanted to be picky.</TD></TR></TABLE>
Well.. I've heard rumors of fixes that were permanent its kinda like trying to find the shaven yak....
Old Nov 30, 2004 | 08:18 PM
C uR eX's Avatar
i have the same problem on my crx..it just the hinge bracket inside the frame is broken off..so everytime you open the door it would make that poping noise and such..what i did to fix that problem was have the door open all the way out and reweld that metal plate around the hinge from the inside(back) and front and it done deal. depending on how your welding is..you might need to grind down the welding after it done so you wouldn't have that messy look.
cvcrcer
33
Jul 7, 2007 09:14 AM
draperj09
Jul 17, 2006 08:11 AM
mixmastabob
10
Oct 13, 2003 07:02 AM
kim_2_da_chee
Aug 31, 2003 02:36 PM
E-lude78
Aug 31, 2002 09:31 AM
