bent valves, changing a few things... need opinions
Old Nov 30, 2004 | 10:11 AM
toEknEEg's Avatar
Default bent valves, changing a few things... need opinions
some of you know about my dumbass mistake while on sebring, misshift from 3rd to 2nd, on video the tach is 1mm away from "0" ... here is the damage...
well i just ordered some supertech high compression stainless steel valves. im gonna get a new head gasket, thinking of getting a spoon one since it is cheaper than OEM ( i think ), but with both of these, this will bump my compression from 11.1:1 ( jdm itr motor ) to about 11.8~11.9 ish...
im already running a kenji prog on my p28. we all know kenji runs rich as hell. my question is would it be in my best interest to get a piggyback, ie. vafc. or could i just get a fuel pressure regulator/gauge and just tune it that way.... i would LOVE to go hondata right now ( OT - i love kpro on my friends rsx-s ) but im in college and dont got that much money left.
but wouldnt i want a rich map for a slightyly higher compression motor? or could i just stay with wat i got? check my garage in my sig for other mods
thanks for your input in advance
Old Nov 30, 2004 | 10:57 AM
Jowee's Avatar
Default Re: bent valves, changing a few things... need opinions (toEknEEg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toEknEEg &raquo;</TD></TR><TR><TD CLASS="quote">
thanks for your input in advance</TD></TR></TABLE>
OEM ITR headgasket is only $45 Spoon is $110 give or take.
Old Nov 30, 2004 | 11:08 AM
Used2beAb16's Avatar
Default Re: bent valves, changing a few things... need opinions (ITR 98 1162)
spoon gasket costs twice as much as OEM. Just buy and OEM gasket and take out the middle layer. Same net effect as Spoon gasket. So many people do it, (including myself) w/o probs.
Old Nov 30, 2004 | 11:10 AM
Default Re: bent valves, changing a few things... need opinions (Used2beAb16)
as far as tuning goes i would atleast do the vafc w/ chipped p28. Fpr is also helpful, but cant tune much with it.
Old Dec 10, 2004 | 02:58 PM
McNizzle's Avatar
if u decide on getting a VAFC i still have the one i had in my coupe...i dont have the book anymore but im sure u could find someone with one...let me know if u want to make an offer on it
Old Dec 10, 2004 | 03:18 PM
mtber's Avatar
Default Re: bent valves, changing a few things... need opinions (Chris M)
vafc is crap for how much it costs...
Read up on http://www.phearable.net/tech/....html
and contact Darin at Titan
Old Jan 7, 2005 | 12:56 AM
McNizzle's Avatar
Default Re: bent valves, changing a few things... need opinions (mtber)
not if he gets a good deal on it
Old Jan 7, 2005 | 06:12 AM
rice4life's Avatar
spoon 2 layer gasket will give you around 11.4:1 cr, and 1 layer will give you around 11.7:1 cr. if you're already running a chipped p28, just buy a rom burner for $80, download crome/uberdata and make your own custom map or just download one with similar engine setup. it's your best option if your not afraid of learning. investing in a wideband wouldn't hurt either.
Old Jan 7, 2005 | 01:22 PM
UncleD's Avatar
Default Re: bent valves, changing a few things... need opinions (rice4life)
If you're adding compression it wouldn't hurt to run more fuel, better to run rich than lean. I personally would only invest in a vafc if you're gonna have it dyno tuned, unless you have experience on the butt dyno.
Old Jan 7, 2005 | 04:59 PM
Rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice4life &raquo;</TD></TR><TR><TD CLASS="quote">if you're already running a chipped p28, just buy a rom burner for $80, download crome/uberdata and make your own custom map </TD></TR></TABLE>
Werd.
Old Jan 7, 2005 | 05:44 PM
BERT-O's Avatar
Default Re: bent valves, changing a few things... need opinions (Rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">
Werd.</TD></TR></TABLE>
hey, what happen to my chip you were suppose to burn me one,lol
Old Jan 8, 2005 | 10:33 AM
Rocket's Avatar
Default Re: bent valves, changing a few things... need opinions (BERT-O)
I'll call you and get you spec's sir!
Old Jan 8, 2005 | 10:41 AM
jdmHboy's Avatar
If I were you I wouldn't invest in a VAFC/piggyback or any best guess ecu, I'd get hondata
Old Jan 8, 2005 | 05:38 PM
BERT-O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">I'll call you and get you spec's sir!</TD></TR></TABLE>
cool beans!!!
Old Jan 9, 2005 | 04:34 AM
BryanPendleton's Avatar
Default Re: bent valves, changing a few things... need opinions (jdmHboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmHboy &raquo;</TD></TR><TR><TD CLASS="quote">If I were you I wouldn't invest in a VAFC/piggyback or any best guess ecu, I'd get hondata </TD></TR></TABLE>
I am not sure what you point is, but I think it is wrong to refer to a VAFC as a "best guess" ecu. If you are tuning without the proper hardware (ie. wide bands and dynos), then you can make a "best guess" ecu out of Hondata or Motec or DFI. Does VAFC offer the control of Hondata? No. Does VAFC provide adequate control for fuel maps on street build? Yes, and that is why it is popular.
ahhwhat?
Dec 26, 2011 01:51 PM
kelvinchau25
Aug 13, 2006 11:30 PM
toEknEEg
Dec 2, 2004 09:58 AM
mr. wu
Jun 28, 2003 12:57 AM
redman223
Jan 8, 2003 06:24 AM
