tokico strut problem?
Old Nov 30, 2004 | 09:28 AM
civic_tuned's Avatar
Default tokico strut problem?
i just recently installed one rear strut and i think i did it right way. I did the same installation with my oem shocks with lowered springs before but i never had this problem. I took the car for a spin and its seem like the strut only absorbs half way then i hear this clanking sound. This shocks are used but the guy i bought them from told me they are in good condition and he has a good vouch thread. Could it be i have to adjust them to a softer setting. I think right now there on a setting 3 or could it be i installed them wrong. As a reminder this is on ej1 with tokico illuminas with same brand lowering springs.
Old Nov 30, 2004 | 09:33 AM
slimstajimsta5's Avatar
Default Re: tokico strut problem? (civic_type_r)
did you cut the bumpstops in half?
Old Nov 30, 2004 | 09:43 AM
Default Re: tokico strut problem? (slimstajimsta5)
U talking about the brown mushy thing right. No i didnot cut them but i did not have that problem with oem strut and lowering spring. Do u think i put them upside down or do think cutting them will solve the problem. Do i cut the bumpstop from the bottom or from the top/ \. THANKS!
Old Nov 30, 2004 | 09:49 AM
AutoXer's Avatar
Cut the bumpstop in half, and install the larger half on the strut.
Is the car at the same ride height as before? Is it possible your LCA is hitting your exhaust / swaybar or something?
Old Nov 30, 2004 | 09:59 AM
Default Re: tokico strut problem? (EX_AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">Cut the bumpstop in half, and install the larger half on the strut.
The rear strut is on the right side so its not hitting the exhaust. Well it does feel like its hitting something hard and it feels like something is loose. the hieght is the same when it was lowered with the oem strut if that helps.
Old Nov 30, 2004 | 10:07 AM
also i would like to know if there is way to adjust them because the shocks did not come with the special tool.
Old Nov 30, 2004 | 10:45 AM
anybody else?
Old Nov 30, 2004 | 10:51 AM
pdiggitydogg's Avatar
I doubt its the bumpstops
Just recheck everything to be sure its tight and that the springs are seated correctly. If it all checks out then try 1/2-ing the stops
The bolts/nuts should be tightened when the car is on the ground.
Old Nov 30, 2004 | 11:07 AM
suspendedHatch's Avatar
Default Re: (pdiggitydogg)
Did you remember to take the metal rings off the OEM strut rods and put them on your Tokicos? The rings that sandwich the bushing where the nut holds it to the little cup on the spring perch. It will be obvious if when the car is on the ground, the strut rods pop out and poke holes in your hood.
Old Nov 30, 2004 | 12:06 PM
FeRioR$'s Avatar
depending on which springs you bought... H&R tells you not to cut the bumpstop...i have Tokico's with H&R .. never had problem... you might want to change the settings
also make sure your **** is compressed in well...
Old Nov 30, 2004 | 12:28 PM
Default Re: (shaundrake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shaundrake &raquo;</TD></TR><TR><TD CLASS="quote">Did you remember to take the metal rings off the OEM strut rods and put them on your Tokicos? The rings that sandwich the bushing where the nut holds it to the little cup on the spring perch. It will be obvious if when the car is on the ground, the strut rods pop out and poke holes in your hood.</TD></TR></TABLE>
yea i did install the sandwich bushings that goes inside the strut mount it must be something else.
Old Nov 30, 2004 | 12:29 PM
Default Re: (FeRioR$)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FeRioR$ &raquo;</TD></TR><TR><TD CLASS="quote">depending on which springs you bought... H&R tells you not to cut the bumpstop...i have Tokico's with H&R .. never had problem... you might want to change the settings
also make sure your **** is compressed in well...</TD></TR></TABLE>
the brand of the springs is the same tokico. how can i change the settings i dont have the special tool and i tried with a flat screwdriver and it didnt work.
Old Nov 30, 2004 | 12:33 PM
Default Re: (civic_type_r)
I installed the strut cover could that be it.
Shinny
Mar 5, 2012 10:33 AM
hastingsr
Suspension & Brakes
12
Feb 4, 2009 08:00 PM
be8teensee1
Dec 29, 2006 11:40 AM
Themouse
17
Jun 17, 2006 09:47 PM
