turbo d16a6 camshaft
Old Nov 30, 2004 | 08:37 AM
rice is nice's Avatar
Default turbo d16a6 camshaft
What camshaft should i get for a d16a6 turbo project? I heard that you want high lift, but no overlap. ???? Anybody got any suggestions?
thanks
Modified by Killa-X at 3:30 AM 12/1/2004
Old Nov 30, 2004 | 08:46 AM
dr_latino999's Avatar
Default Re: turbo d16a6 camshaft (Killa-X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by http://sdsefi.com/techmods.htm &raquo;</TD></TR><TR><TD CLASS="quote">Because turbo engines usually have lower compression ratios than atmo engines, they do not take kindly to hot cams on the street. The gain in top end will almost always be offset by a huge loss in the lower powerband and more turbo lag. Stock cams are the way to go on most turbo street engines. Don't waste your money on so called "turbo cams" for 4 and 6 cylinder engines. These may boost economy slightly but they almost always lose power. Most of these were designed by guesswork rather than by actual turbo experience. 4 Valve engines in general when turbocharged do not need hotter cams for the street.</TD></TR></TABLE>
Old Nov 30, 2004 | 06:30 PM
Default Re: turbo d16a6 camshaft (dr_latino999)
what about crane cams
part number
251-0014
Advertise Duration: Int=232 / Exh=228
Duration @ .050: Int=206 / Exh=202
Lobe Separation: 110
Gross lift: 394/376
Stock
Advertise Duration: Int=222 / Exh=224
Duration @ .050: Int=194 / Exh=196
Gross lift: 333/362
it's slightly more duration then stock, but with a lot more lift? They said on the site, that the exhaust is less then the intake duration to promote spool up.
Old Nov 30, 2004 | 06:41 PM
mrspeaker's Avatar
The zex 59300 cam helps with spool
Old Nov 30, 2004 | 06:47 PM
drdisco69's Avatar
Default Re: turbo d16a6 camshaft (Mrspeaker)
I'd be interested in dyno tests of some turbo cams. I'm sure someone has done it, just not as common as the skunk vs. jun wars.
mozzandherb
Dec 19, 2005 09:20 AM
murtnabila
Jul 26, 2005 08:53 PM
darkcrx
30
Apr 6, 2004 05:28 AM
Dorikamu
Jun 13, 2002 06:05 PM
