HELP! DON'T KNOW WHICH WAY TOP PISTON RINGS SIT!
ok i need help quick i have a set of stock honda rings i ordered and i pput the bottom oil rings on. and now i am putting the top two rings on and they have a taper around the edge of the ring. also the letter "N" sits on each side of the top two. i don,t want to put theese on backwards. so does anyone know which way the rings sits on the piston? does the "N" face up or down. or will that little taper even matter which way it faces? thanks.
98Luder
17
Dec 18, 2012 02:07 AM
