changing cv joints
Old Dec 30, 2001 | 09:01 PM
95gsr's Avatar
Default changing cv boots
yes I did a search and could not find it anywhere. but whos changed there cv joints I only need the outer ones changed. in it a PITBalls. and tricks of the trade any type of tools needed other than 10 12 14 mm socket thanks
edit: sorry i ment to say boots
[Modified by 95gsr, 10:08 PM 12/30/2001]
Old Dec 31, 2001 | 09:46 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: changing cv boots (95gsr)
Just buy reman axles, lifetime warranty. 15 minutes to change.
Will take you at least a hour per side just to rebuild a joint + the mess.
Old Dec 31, 2001 | 03:00 PM
95gsr's Avatar
Default Re: changing cv boots (Mista Bone)
only 15 mins. you work in some speed shop or soomething. how you pull that off. tell me plz
Old Dec 31, 2001 | 03:11 PM
speedymon's Avatar
I heard reman axles are bad. where do you get them.
Old Dec 31, 2001 | 03:16 PM
95gsr's Avatar
Default Re: changing cv boots (speedymon)
well all i need to do is replace the boot it is not cracked. starting to wear out. so is it needed to rebuild everything
Old Dec 31, 2001 | 03:39 PM
Mista Bone's Avatar
D Tranny Guru
4 lug nuts, lower fork bolt/nut, lower ball joint, pop apart the ball joint, swing knuckle out of way, pop out axle.
Proper tools is all it takes.
Air tools are a big help.
sanman000719
Jul 7, 2011 07:47 PM
sony224422
Jul 7, 2007 03:29 PM
sam385
16
Oct 19, 2005 03:32 PM
jovial111
14
Apr 14, 2004 05:59 PM
95gsr
Jun 1, 2002 12:32 PM
