b16 not starting...have power but just a hum when i turn the key?
Old Nov 30, 2004 | 06:55 AM
dingusjt's Avatar
Default b16 not starting...have power but just a hum when i turn the key?
the b16a1 wouldn't start this morning...i have power I checked all my connections and grounds both at battery and at the starter side. and I've never had any starting issues before
now when I turn the ignition i just hear a humm and there is no cranking, ticking, or anything. what's going on??
Old Nov 30, 2004 | 07:38 AM
1RMDave's Avatar
Default Re: b16 not starting...have power but just a hum when i turn the key? (dingusjt)
pull the starter off and test it manually.
Old Nov 30, 2004 | 07:57 AM
dingusjt's Avatar
Default Re: b16 not starting...have power but just a hum when i turn the key? (1RMDave)
you mean just rotate it and see?
Old Nov 30, 2004 | 10:38 AM
Ef-er's Avatar
bench test it, run wires off a good battery and test it
Old Nov 30, 2004 | 11:44 AM
Zaakro's Avatar
Default Re: b16 not starting...have power but just a hum when i turn the key? (ChineseGuy)
put the car in gear and rock the car back and forth and i mean you have to push hard, then try and starting it. if it doesnt start try push starting, if that doesnt work then you know its not the starter.
DJBLUEB20
May 15, 2017 07:11 PM
CzA
Apr 24, 2007 07:53 PM
R-81DC2
May 22, 2006 01:33 PM
cvc323
Nov 20, 2003 10:51 AM
mingchi69
Jul 14, 2003 06:14 PM
