Clutch Master Cylinder problem
Old Nov 29, 2004 | 08:15 PM
xprohx's Avatar
I think too much
Default Clutch Master Cylinder problem
Apparently my clutch master cylinder is "leaking, bad" as quoted by my dealer. They said they had to top off the fluid for me. I was also quoted $300 to replace.
My question is has anyone replaced this before. Do you recommend oem or will an aftermarket one work? Any tips/tricks in replacing it?
tia
Old Nov 29, 2004 | 09:42 PM
jdmcivicferio's Avatar
Default Re: Clutch Master Cylinder problem (xprohx)
$300? the part costs $110cdn and labour can't be more then $70
I blow mine at least once a year because of the clutch I am using, you can take out the old one and bleed the new system and be done in 30-45min, you might as well do the slave cylinder while your at it
Old Nov 29, 2004 | 09:47 PM
Sack Master's Avatar
Default Re: Clutch Master Cylinder problem (jdmcivicferio)
Seriously go to kragen and get one for like $90 brand new. And do it yourself. It's a couple bolts, a clamp, a hydraulic line, and a cotter pin. First time I would guess an hour maybe a little more to do it.
Old Nov 30, 2004 | 09:52 AM
rgaray's Avatar
$120 tops for both master and slave, 1 hr tops for install and bleeding. Having a friend to help bleed the lines makes it easier.
Old Nov 30, 2004 | 03:43 PM
xprohx's Avatar
I think too much
Default Re: (rgaray)
I plan to do this myself. Anyone have the steps to do it?
deathtoinvader0
Honda Civic (2006 - 2015)
Feb 1, 2019 08:30 PM
delorean
Jun 26, 2011 06:00 PM
phookie
Jan 27, 2009 08:25 PM
obuhmyuh
Apr 19, 2008 02:14 PM
digital sol
184
Oct 30, 2005 01:49 PM
