need info on throttle bady spacer 4 95 f22b1
Old Nov 29, 2004 | 06:14 PM
1lo95's Avatar
Default need info on throttle bady spacer 4 95 f22b1
Can anybody tell me if a throttle bady spacer will do anything to my 95 accord with f22b1 Vtec? The one i am getting is a Poweraid throttle body spacer with the power ports.im getting this one because i want an easy way to hook up a air/fuel meter and nitrous in the distant future.I really need to know hp numbers or if you can feel a difference.any info will help thanks.
Old Nov 29, 2004 | 06:17 PM
-RedneckDave-'s Avatar
Working
Default Re: need info on throttle bady spacer 4 95 f22b1 (1lo95)
You are not going to notice a throttle body spacer making any difference.
Old Nov 29, 2004 | 06:37 PM
pyrojeff's Avatar
It won't do anything for performance at all. I can't see how you can hookup an a/f meter with it, because the spacer just increases the space between the intake manifold and throttle body, way before fuel is even injected.
However, if it is the type of throttle body spacer that has the hole for a nitrous line, it is perfect for a dry nitrous setup. This way you wont have to make any modifications to the intake tube for nitrous lines
Old Nov 29, 2004 | 08:22 PM
iam7head's Avatar
Default Re: need info on throttle bady spacer 4 95 f22b1 (pyrojeff)
they work good for carb'ed american V8 and that's about it
Old Nov 29, 2004 | 08:39 PM
accordselux's Avatar
Me Gusta History
Default Re: need info on throttle bady spacer 4 95 f22b1 (iam7head)
Yeah, they're a hangover from the muscle cars. The trick worked on the big cubics with carbs but not on a EFI 4 cylinder. That and big bore throttle bodies---much better gains on the Hemis of yesteryear
Old Nov 29, 2004 | 11:17 PM
TOAB's Avatar
worked on old cars because it gave time for things to cram, and get mixed. youre trying to space out your air before it even hits the throttle body... its not gonna do anything.
Old Nov 30, 2004 | 04:14 AM
iakona's Avatar
they do have a nice jet engine whine when you're at WOT though.
BigBlock22
Sep 30, 2009 12:44 PM
fliP
Dec 30, 2004 10:28 AM
Nikos
Sep 4, 2002 11:15 AM
97V6ACCORD
Jun 7, 2002 09:15 AM
