attn comptech sway bar tie bar owners
has anyone ever replaced the bushings with greasable ones if so did it have any negative effects on it at all
o and if it matters it is on a 97 ex
thanks for any help
thanks for any help
Installed grease fittings in the d-brackets when I installed the bar. Greased the bushing when I installed the bar but I haven't had the need to regrease in 2 years. No downsides of having the grease fittings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 »</TD></TR><TR><TD CLASS="quote">Greased the bushing when I installed the bar but I haven't had the need to regrease in 2 years. </TD></TR></TABLE>
I greased mine with Castrol Marine Grease. Been good for a year now, so I think that grease fittings might not be worth the hassle.
My tape and initial grease up lasted less than 6 months. I typically have to regrease every 6 to 10 months or so. Last time I used some marine grade stuff and it doesn't seem to last any longer.
SyDuck
Aug 19, 2006 03:41 PM
Legacy_CPA
Mar 26, 2002 11:59 AM
