Coolant inside cylinder?
Old Nov 29, 2004 | 05:27 PM
vtec.dc2's Avatar
Default Coolant inside cylinder?
I'm guessing cylinder head is cracked somewhere? It can't be anything minor right? Entire cylinder is filled with coolant because its covering spark plug.
Old Nov 29, 2004 | 05:37 PM
85's Avatar
85
Default Re: Coolant inside cylinder? (vtec.dc2)
it could be minor. its one of 3 things
1. cylinder head cracked
2. cylinder sleve cracked
3. blown head gasket
ither way the head has to come off good luck
Old Nov 29, 2004 | 05:39 PM
Kamin's Avatar
Default Re: Coolant inside cylinder? (hks85)
ive also seen coolant fill the cylinder form botched skunk 2 manifold installs, they dont use the cooler lines.
Old Nov 29, 2004 | 05:42 PM
DelsoldS's Avatar
the cylinder wouldn't fill all the way up like that from a bad head gasket would it?
Old Nov 29, 2004 | 05:43 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Coolant inside cylinder? (Kamin)
Just one cylinder? Small rupture in the headgasket is probably to blame; a relatively easy fix in my opinon. If it's a sleeve, time for long-term boost plans
Old Nov 29, 2004 | 05:45 PM
Unceasing Measure
Default Re: (DelsoldS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelsoldS &raquo;</TD></TR><TR><TD CLASS="quote">the cylinder wouldn't fill all the way up like that from a bad head gasket would it?</TD></TR></TABLE>
After you shut the car off, the coolant is still under a shitload of pressure. If there's a rupture in the gasket, coolant will pour into the most readilly available expansion chamber, be it your radiator, your overflow bottle or your cylinder. How did you discover this catastrophy? I ask because cranking a flooded cylinder is a wonderful way to bend valves and/or rods.
Old Nov 29, 2004 | 05:55 PM
vtec.dc2's Avatar
Default Re: (Archidictus)
started the car one morning and entire car was shaking. i thought it was misfiring or broken mount, turned the car off, and few minutes later started pulling spark plug wires and one cylinder was completely filled.
car was loosing coolant every now and then prior to this
Old Nov 29, 2004 | 07:34 PM
vtec.dc2's Avatar
Default Re: (vtec.dc2)
up for the night
Old Nov 30, 2004 | 08:07 AM
vtec.dc2's Avatar
bump
Old Nov 30, 2004 | 02:48 PM
vtec.dc2's Avatar
any help?
Old Nov 30, 2004 | 03:06 PM
Falqon's Avatar
dude, your help was covered in the 2nd post, immediately after your question. It's your turn to help yourself.
Old Nov 30, 2004 | 03:23 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">any help?</TD></TR></TABLE>
what help do you want? your engine is toast
replace it or upgrade
Old Nov 30, 2004 | 03:31 PM
vtec.dc2's Avatar
i see.. i'm going to pull the head and take it from there..
now.. if i have to replace the block (D15B7) and this is automatic, any d series block will work, right?
yia.yang09
Engine Machining & Assembly
Jun 16, 2016 06:18 PM
Migs19
May 28, 2016 03:48 PM
Cheapshot1979
Apr 8, 2015 09:03 AM
blackmfoggie
Jun 9, 2007 04:49 PM
deascendent
Apr 3, 2004 08:39 AM
