car is hard to start after taking out furl cap need hellllpp
Old Nov 29, 2004 | 05:18 PM
sillydrifter's Avatar
Default car is hard to start after taking out furl cap need hellllpp
i have a 99 civic with a 95 gsr wiring harness was done by place racing and everytime i go to get gas it hard to get it started. i have to crank it for like 3-6 sec with gas before it fires up. after fueling the car starts like normal. i just cant figure it out. my setup 255 lph, hondata s200b, 550cc.
Old Nov 29, 2004 | 05:38 PM
Archidictus's Avatar
Unceasing Measure
Default Re: car is hard to start after taking out furl cap need hellllpp (sillydrifter)
Why do have bigger injectors and a huge fuel pump? It might be that you're running so pig rich that your car floods a little bit due to the increase in available fuel pressure right after you fill up. Dunno.
Old Nov 29, 2004 | 06:45 PM
well im boostin and running the injector at about 60-70% duty cyle. also the af is at mid 11
Old Nov 29, 2004 | 06:46 PM
need more help
Old Nov 29, 2004 | 08:01 PM
Master23's Avatar
You could be running too rich which will make it harder for your car to start up.
Old Nov 29, 2004 | 08:14 PM
but this only happens right after i refuel other then taht it starts up like every other car and the car idles and run perfectly.
Old Nov 30, 2004 | 02:29 PM
does anyone have this problem
Old Nov 30, 2004 | 10:40 PM
helpp
Old Nov 30, 2004 | 10:44 PM
marshun's Avatar
Default Re: (sillydrifter)
you tried just unhooking the battery for a little bit?
it usually works for me.
Old Dec 1, 2004 | 12:14 PM
no but ill try it
Old Dec 1, 2004 | 01:46 PM
{StatuS ChecK}'s Avatar
Mids 11s AF, are nice for a turbo setup. I have a 255 Fuel Pump and 550 cc injectors (to big for a single cam<---me). But 11s are not going to keep your car from starting. I am at low 10s on my AirFuel ration at idle, And the only bad thing that happends is that I go through plugs once a month.
HINT : For a Turbo CIvic you should check your Spark Plugs and Oil, Once a Week...yes that means takeing out the plugs. But for us lucky Civic owners, that only takes us 10 Minutes. HA HA V8's.
SpeedoKing
Nov 15, 2008 07:22 PM
94civls
Dec 6, 2007 04:59 PM
dan89crxsi
16
Sep 24, 2006 01:22 PM
POWERINTEGRA
Jan 15, 2005 10:06 PM
Norcalstoppy
Oct 27, 2003 02:14 PM
