CAI 3" vs 2.5"
Old Nov 29, 2004 | 03:33 PM
zumiez007's Avatar
Default CAI 3" vs 2.5"
What's the difference performance wise between using a 3" pipe and a 2.5" pipe? For a 92 accord (2.2L) which is recomended?
Old Nov 29, 2004 | 03:37 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: CAI 3" vs 2.5" (zumiez007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zumiez007 &raquo;</TD></TR><TR><TD CLASS="quote">What's the difference performance wise between using a 3" pipe and a 2.5" pipe? For a 92 accord (2.2L) which is recommended?</TD></TR></TABLE>
It depends on the engine. The AEM CAI for the F23 is 2.25" [I think] and it's 3" for the H22. I don't think you would gain any significant power with a 3" pipe on a stock engine, but I could be wrong.
Old Nov 29, 2004 | 05:13 PM
zumiez007's Avatar
Default Re: CAI 3" vs 2.5" (-Bionic-)
I tried a short ram 3" but found that I had lost all of my lowend torque, however highend was increased. Now I have a 2.5" ebay CAI, the lowend torque is better than with the 3"
Old Nov 29, 2004 | 05:49 PM
accordselux's Avatar
Me Gusta History
You won't see much of a difference at all. Actually you might lose power because there is too much space in the tube that the air does not 'funnel' properly, plus if it's bigger you might get it closer to the engine and it will heat the air more...which is bad. I would stick with a 2.25 in intake unless youve got a need to (ie nitrous, larger diameter piping for a turbo....)
Old Nov 29, 2004 | 06:55 PM
pyrojeff's Avatar
Default Re: CAI 3" vs 2.5" (accordselux)
I doubt there will be any difference at all.. It's not like these engines are consuming enormous amounts of oxygen. These aftermarket tubes arent really improved over the factory design. Just go with which is cheaper.
Old Nov 29, 2004 | 08:10 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zumiez007 &raquo;</TD></TR><TR><TD CLASS="quote">I tried a short ram 3" but found that I had lost all of my lowend torque, however highend was increased. Now I have a 2.5" ebay CAI, the lowend torque is better than with the 3"</TD></TR></TABLE>
show me dyno sheet first.
Old Nov 29, 2004 | 09:32 PM
pyrojeff's Avatar
Default Re: CAI 3" vs 2.5" (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly. Any gains/losses you may have had were either attributed to the increase in sound, or even the placebo effect.
Old Nov 29, 2004 | 10:35 PM
Me Gusta History
Did you see what he wrote though? He had a 3" SHORT RAM and replaced it with a 2.5" COLD AIR INTAKE.
Anyone able to guess why the torque is different???
Old Nov 29, 2004 | 11:13 PM
TOAB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zumiez007 &raquo;</TD></TR><TR><TD CLASS="quote">I tried a short ram 3" but found that I had lost all of my lowend torque, however highend was increased. Now I have a 2.5" ebay CAI, the lowend torque is better than with the 3"</TD></TR></TABLE>4 cyl engines dont really have low end anything to begin with.
Old Nov 29, 2004 | 11:25 PM
pyrojeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordselux &raquo;</TD></TR><TR><TD CLASS="quote">
Anyone able to guess why the torque is different??? </TD></TR></TABLE>
Pfft, cold air intakes are overrated. Just an easier way to hydrolock the engine.
Old Nov 29, 2004 | 11:34 PM
TOAB's Avatar
hydrolocking is a myth created by intake manufacturers ti get you to spend more on something with a bypass valve or whatever theyre called.
...dont drive in water thats deep enough to **** the carpet in your car and youre fine.
Old Nov 30, 2004 | 08:35 AM
pyrojeff's Avatar
Default Re: (TOAB)
Myth my ***. I just searched for "hydrolock" and there were 69 results, a lot of them dealing with fucked up engines.
It DOES happen. Hell, there was even a topic just a few days ago in this forum about someone who hydrolocked.
And it's not like you can just avoid driving through water sometimes.
Old Nov 30, 2004 | 08:43 AM
KGAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zumiez007 &raquo;</TD></TR><TR><TD CLASS="quote">What's the difference performance wise between using a 3" pipe and a 2.5" pipe? For a 92 accord (2.2L) which is recomended?</TD></TR></TABLE>
you could always buy a 92-96 prelude aem cai which is 2.75 inch pipe since the base lude was equipped with a F22, but a 3 inch CAI on that F22 would be too large.
most instances of hyrdrolock are do to a stupid driver, ie: driving too fast in a heavy rainstorm and driving through huge puddle and not installing the splash sheild in the wheel etc. keep in mind when the rpms are high it creates a stronger vaccum to suck up the water, so mostly likely to injest enough water to hydrolock the rpms were up past 4k rpm through a big puddle which is just stupid in any car.
Old Nov 30, 2004 | 09:22 AM
bthrist's Avatar
I agree most cases of hydrolocking is probably due to improper driving in bad conditions (puddles, etc.), my point is that it happens and for those who have hydrolocked, I'm sure they don't think of it as a a myth.
Old Nov 30, 2004 | 09:57 AM
TOAB's Avatar
Default Re: (pyrojeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pyrojeff &raquo;</TD></TR><TR><TD CLASS="quote">Myth my ***. I just searched for "hydrolock" and there were 69 results, a lot of them dealing with fucked up engines.
And it's not like you can just avoid driving through water sometimes.</TD></TR></TABLE>i was also joking tard. i've seen the threads.
dont be an idiot and get water in your motor... its not like its hard to keep that from happening.
Old Nov 30, 2004 | 02:27 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: (TOAB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOAB &raquo;</TD></TR><TR><TD CLASS="quote">hydrolocking is a myth created by intake manufacturers ti get you to spend more on something with a bypass valve or whatever theyre called.
...dont drive in water thats deep enough to **** the carpet in your car and youre fine.</TD></TR></TABLE>
lol
jonsey1886
26
Apr 9, 2013 09:01 AM
dayaftertomorrow
Nov 19, 2006 02:01 AM
Lil BAiLeY IV
Nov 24, 2005 09:49 PM
CiViC SiR
Nov 23, 2005 06:58 AM
AzntaggeR
Apr 11, 2005 11:57 PM
