Integra 1999 GSR not passing smog at REF
Old Nov 29, 2004 | 03:21 PM
BobGnarly's Avatar
Default Integra 1999 GSR not passing smog at REF
Hey guys,
Ive searched the forums for a while but I cant find anythign so im jsut ganan post my own thread. Here it goes. I got turboed about begining of this year and I then got a referee ticket about 1 month ago. I then took my car to AutoWave in huntington beach and there pretty awsome there. THey put my car back to stock its exactly stock. I get my car pre smogged and it passes. I goto the referee and I get 160 HydroCarbons max is 61 which is messed up anyways pretty pissed. I bring it back to autowave they put a new O2 sensor in cause it was probably bad. Got my car smogged and it barely passes. I go home and do a seafoam my car cause my turbo probably got my car all dirty. ANyways i run that through my system and i drive it for about 70 miles. I got new spark plugs to. I go back to a smog place arround here and I asked him to do one for free cause I already payed one time. He hooks it up really quick to see what its putting out on idle. Its like 300 at idle. Gahh pissing me off. He told me to run down the freeway and fill up my tank and come back. So I come back after going a little on the freeway then filling up my tank. Gas the **** out of it redlining it all the way back. Get back we throw it on. 15 MPH test it passes but it is 61/61 I pass by nothing the wind can change that. I jsut bought a new air filter hopefully that will help.
Does anyone have any ideas? My car smells bad and smokes at idle and puts out alot of fumes even tho its stock new o2 new sparks new air filter....
thank you in advance
Old Nov 29, 2004 | 06:17 PM
BobGnarly's Avatar
Default Re: Integra 1999 GSR not passing smog at REF (Ultraroms)
uo
Old Nov 29, 2004 | 06:34 PM
Honduh Chicken's Avatar
I fry gay turkeys
I don't understand, your car passed just fine pre turbo, then after they took the turbo off it won't pass?
Was your ecu flashed? (chipped)
How many miles are currently on your car?
Were you running really lean while boosted? (you may have inturnal damage)
I can't think of any other reason, but it sounds like if the motor wasn't damaged that it's an ECU problem.. see if someone has a wideband and see if it it's running too lean/rich. Then post the results.. Someone on here can help you..
BTY: IMO California sux, in wisconsin I don't even have to take my car into emissions tests at all.. I have no cat.
WI>CA (Pollution Pwnz j00)
Old Nov 29, 2004 | 06:40 PM
BobGnarly's Avatar
Default Re: Integra 1999 GSR not passing smog at REF (Honduh Chicken)
No i never got it smogged with the turbo. everything was with the turbo off
Old Nov 29, 2004 | 07:16 PM
NightRiderS2K's Avatar
In-N-Out Burger
Stock air filter right? With new air filter on it?
How is the cat? Stock I assume? But how old?
HydroCarbons mean unburned fuel that seeped past through the combustion chamber and out to your exhaust.
Old Nov 29, 2004 | 09:38 PM
BobGnarly's Avatar
Default Re: Integra 1999 GSR not passing smog at REF (NightRider-gsR)
Stock air intake is on bought a new air filter today. Catylitic converter is brand new.
Old Nov 30, 2004 | 06:28 AM
BobGnarly's Avatar
up
Old Nov 30, 2004 | 07:29 AM
I fry gay turkeys
if it's all back to normal, and you don't have any timing issues, I would sug. putting a wideband on it and see how it's running (lean rich) also, have you changed the plugs? that's odd because a 99 GSR should pass with no problems. unless somethings is wrong.
Old Nov 30, 2004 | 11:49 AM
BobGnarly's Avatar
i only got 1 new o2 sensor.
I got all new spark plugs today im ganna put on a brand new air filter and hopefully that will make a difference. Were can i find someone with a wideband?
thanx
Old Nov 30, 2004 | 03:41 PM
I fry gay turkeys
your shop should have one, if they do a lot of tuning, it's basically just an o2 sensor that goes to a gauge... check around, because they have to know how to use it properly to help you any, but once it's hooked up you can see if your cars running lean... dude, try to reset your computer. I'm thinking since you had the turbo on, you were pushing more air, thus the need for more fuel wa s"learned" by the ecu and it hasen't had a chance to re-adjust back to normal.... I could be wrong.. anyone else think so?
Old Nov 30, 2004 | 09:20 PM
BobGnarly's Avatar
they reset the ecu after they put the new o2 sensor in it
Old Dec 1, 2004 | 04:54 AM
I fry gay turkeys
Well, I'm going to go with running rich or, timing is off.
Old Dec 1, 2004 | 06:51 AM
BobGnarly's Avatar
timeing was set to 16.... im gnana try and reset my ecu.
Old Dec 1, 2004 | 06:53 AM
I fry gay turkeys
let me know the outcome.... What type of plugs are you using? those platnum bullshit plugs are garbage... get youself some NGK cheapos. otherwise, just sell the car to me..
Old Dec 1, 2004 | 07:33 AM
n2ob16hatch's Avatar
what ECU you runnin on? maybe the timmin does a difference.. set everything back to stock and stock specs.. maybe that well help.. im in texas is its not all that bad over here. thank God.
Old Dec 1, 2004 | 08:35 AM
stareatsun's Avatar
When you use seafoam, you are not suposed to drive the car. You are suposed to put in in th crankcase and then rev for a while, no load. then change oil, plugs, o2 sensor and anything else you want. if its in your gas tank, you will fail also.
Old Dec 1, 2004 | 08:37 AM
Hulkdon1's Avatar
You check for any exhaust leaks before the o2 sensors. Any fresh air to the sensors will tell the ecu to dump more fuel. If the ignitor unit in the distributor is old or burning out, the combustion won't be as clean. You should try another distributor. Good luck.
Old Dec 1, 2004 | 11:00 AM
I fry gay turkeys
Default Re: Integra 1999 GSR not passing smog at REF (Hulkdon1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hulkdon1 &raquo;</TD></TR><TR><TD CLASS="quote">You check for any exhaust leaks before the o2 sensors. Any fresh air to the sensors will tell the ecu to dump more fuel. If the ignitor unit in the distributor is old or burning out, the combustion won't be as clean. You should try another distributor. Good luck.</TD></TR></TABLE>
good advise smiley..
Old Dec 1, 2004 | 11:20 AM
threatcon13's Avatar
New User
I have no cat.
WI&gt;CA (Pollution Pwnz j00)[/QUOTE]
Old Dec 1, 2004 | 11:23 AM
I fry gay turkeys
Default Re: Integra 1999 GSR not passing smog at REF (threatcon13)
what's wrong with that? I have a "test pipe" cat's suck.. especially with a turbo car.
Old Dec 1, 2004 | 02:40 PM
BobGnarly's Avatar
i got to a wideband and the second o2 sensor was a slug bug and wasnt reading good even at all.
Old Dec 1, 2004 | 03:49 PM
Racermech's Avatar
Default Re: Integra 1999 GSR not passing smog at REF (ActuallyKnowsAboutHonda)
Charcoal canister???? never heard of this.......any other info??
Old Dec 1, 2004 | 05:11 PM
In-N-Out Burger
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ActuallyKnowsAboutHonda &raquo;</TD></TR><TR><TD CLASS="quote">Your car is running to rich because your timing is off, or your vacuums might be all haywire. anyway check the charcoal canister, and is ur car throwing any codes?
Are you an idiot? Or you wish you just really knew what you were talking about?
His timing is set stock at 16BTC.
I failed smog before UltraRoms, but I managed to pass after the 2nd try and legally...you might want to read up on my thread:
https://honda-tech.com/zerothread?id=895526
edit: forgot the link^^^
Modified by NightRider-gsR at 12:56 AM 12/3/2004
Old Dec 1, 2004 | 05:34 PM
I fry gay turkeys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightRider-gsR &raquo;</TD></TR><TR><TD CLASS="quote">
His timing is set stock at 16BTC. What the **** is a charcoal canister? Do you mean Catalyc Converter?
https://honda-tech.com/zerothread?id=895526</TD></TR></TABLE>
bwhaeeehahahahehe *sigh*
nuff said..
Thanks for the link though..
I'm curious what the prob is myself.
Old Dec 1, 2004 | 05:53 PM
Racermech's Avatar
My fav part is the user name..........
then again I am allmost as bad. I questioned myself about the "canister". Thinking about charcoal filters for AC units(home/office). o well live and learn...lol
