how to repair rear sway bar tearout?
Old Nov 29, 2004 | 01:49 PM
JCushing's Avatar
Default how to repair rear sway bar tearout?
well my skunk2 bar came off my DC4 today cause i was gonna put on some new endlinks since the ones it came with were junk (one backed out of the LCA). i had the pleasant supprise of breaking a bolt off in one of the mounting holes. when i went to easy out the bolt the whole area where the nut plate basically crumbled away....
ill take some pics tomorrow but basically what am i gonna have to do to fix this thing
Old Nov 29, 2004 | 03:56 PM
JCushing's Avatar
Default Re: how to repair rear sway bar tearout? (JCushing)
heres the damage
and the new endlinks i was gonna use compared to the old ones
Old Nov 29, 2004 | 07:42 PM
Denny Crane's Avatar
One of the (many) costs of living in the Rust Belt.
Old Nov 29, 2004 | 07:57 PM
mmuller's Avatar
Mad Scientist
Default Re: how to repair rear sway bar tearout? (hybrid2nr)
you can weld and re-tap.
even better you could make a steel plate and have it welded on top of the stock mounting holes; then re-tap. Kinda like the beaks kit, but weld on.
Old Nov 29, 2004 | 08:51 PM
Greenery18's Avatar
Default Re: how to repair rear sway bar tearout? (mmuller)
what kind of endlinks are those? I need some for my 22mm bar...
Old Nov 30, 2004 | 02:21 AM
JCushing's Avatar
Default Re: how to repair rear sway bar tearout? (Greenery18)
the endlinks are just a male and female heim joint... the ones on the right are the garbage that you get with a skunk2 kit. the center allen key all stripped out and the ball joints went bad. broke my hex socket in them. i basically had to cut them off the sway bar. that didnt stop one from coming out of the passenger lca on its own though.
since i cant weld i was thinking of making a plate that bolts to the lca bolt and a couple other ones covering the whole area, then tapping a couple holes in it for the sway bar... maybe drill through and put a nice ling 10mm bolt through the whole subframe to the right of where that nut ripped out. that would be pretty strong.
i dont want to have to re use any of the skunk2 crap besides the bar
Old Dec 7, 2004 | 02:01 PM
JCushing's Avatar
anyone else?
gonmaro
Suspension & Brakes
Apr 8, 2009 05:31 PM
96 GSR-T
Suspension & Brakes
Mar 11, 2008 07:21 PM
shotgun2224
Feb 18, 2008 10:10 PM
dc4teg95
Apr 30, 2007 09:30 AM
Bigmojoj27
Nov 28, 2006 10:11 PM
