using d15 altenator on b16 ?
Old Nov 29, 2004 | 01:44 PM
'91 CRX CornerCarver's Avatar
Default using d15 altenator on b16 ?
hey i am about to swap a b16 into my crx and i was wandering if i could use my almost new d 15 altenator on the b16 swap ?
Old Nov 29, 2004 | 02:10 PM
Zaakro's Avatar
Default Re: using d15 altenator on b16 ? ('91 CRX CornerCarver)
no cuz its a d15 altenator
Old Nov 29, 2004 | 02:24 PM
Default Re: using d15 altenator on b16 ? (Zaakro)
well the plug in looks the same on booth and it sure would save some money
Old Nov 29, 2004 | 02:26 PM
T--Rex's Avatar
No and Yes. You cant just slap it on and go. first of all the b16 alternator has a different size belt, i believe it would be possible if you did change out the voltage regulator and a few other parts, not sure which though. I had one of those high output 150A alternators to power my sterio, when i did my b16 swap i asked the same question and was told you would have to change a few parts but it would be possible to still keep the same alternator. I never actually went through with that because i decided to sell the sterio and go turbo.
Anyone else done this?
Old Nov 30, 2004 | 01:15 AM
Nerologic's Avatar
Default Re: using d15 altenator on b16 ? (Matrix_Zero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zaakro &raquo;</TD></TR><TR><TD CLASS="quote">no cuz its a d15 altenator</TD></TR></TABLE>
um sorry it DOES work
its easy to put it on
the thing aligns up almost perfect.
all u have to do is run a few washers where the bottem bolt goes and your set
as for voltage, i would worry about it because if its not the same, its damn near close and as for the belt, it all depends on the crank pully u have...
Old Dec 1, 2004 | 06:36 PM
CrazyKoreanCrx's Avatar
Default Re: using d15 altenator on b16 ? (Nerologic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nerologic &raquo;</TD></TR><TR><TD CLASS="quote">
as for voltage, i would worry about it because if its not the same, its damn near close and as for the belt, it all depends on the crank pully u have...</TD></TR></TABLE>
I did that to my swap for the alternator. If you're using the b-series crank pulley get the b-seires alternator belt. But you need to switch the pulley on the d-series pulley with a b-series pulley. If that makes sense.
87hondaguy
Jul 1, 2011 06:58 PM
hondacrxsiguy
24
Dec 17, 2007 05:11 AM
smokez187
May 4, 2007 10:59 AM
kos99ngel
24
Sep 15, 2005 05:02 PM
