altenator belt deflection
Old Nov 29, 2004 | 12:10 PM
NZDelsoldude's Avatar
Default altenator belt deflection
I'm just about to remove my A/C compressor. I'm probably being fussy but in my manual it has the altenator belt deflection with and without A/C. Plus new and old belt deflections. Once removed should i adjust it? Should I use the with AC deflections after or is that only for a car without A/C stock? Or should I only worry if it slips and does'nt charge properly?
Cheers Greg
Old Nov 29, 2004 | 12:28 PM
snatch's Avatar
Default Re: altenator belt deflection (NZDelsoldude)
I really wouldn't worry about it unless you hear whining from that area implying the belt is too loose or tight. If you're removing only the A/C, you shouldn't have to remove the alternator belt.
Old Nov 29, 2004 | 12:56 PM
Default Re: altenator belt deflection (******)
Thanks mate. Off it comes then.
Hill4589
Nov 14, 2008 12:26 PM
oxSLEEPERxo
Mar 20, 2005 11:23 AM
speedaholic92
Sep 13, 2003 02:03 PM
andrewasf77
Jul 8, 2003 12:14 PM
Atiyeh
May 30, 2002 03:34 PM
