help...frozen crank pulley bolt
Old Nov 29, 2004 | 11:06 AM
seraniko's Avatar
Default help...frozen crank pulley bolt
any tricks in loosening a stuck crank pulley bolt on a older accord? is it clockwise to lossen it?
Old Nov 29, 2004 | 11:08 AM
Turbowa's Avatar
Default Re: help...frozen crank pulley bolt (seraniko)
One word: SEARCH. Its been covered a hundred times. You'll will have to use some ***** to get it off.
Old Nov 29, 2004 | 11:24 AM
TouringAccord's Avatar
H-T Order of Merit
yes, search. If you search the archives of the Accord forum alone you'll get 99 results related to "timing belt". Here is one where this guy was having a big problem getting his off. There are some good suggestions and one not so good one IMO, you'll see what I mean.
https://honda-tech.com/zerothread?id=912676
Old Nov 29, 2004 | 11:28 AM
Beach Accord's Avatar
use a cheater pipe, extra long.....
use an impact gun (IR titanium 1000ftlb works well)
Old Nov 29, 2004 | 12:52 PM
TOAB's Avatar
those things never come off.. only things ive seen workis a big big impact.
Old Nov 29, 2004 | 01:23 PM
alotawatts's Avatar
I have never pulled one but (your question of direction) I do not think it's reverse threaded ! The crank/pulley spins counter-clockwise right ? Righty-tighty lefty-loosey ?
Old Nov 29, 2004 | 01:57 PM
arielb1's Avatar
Correct, counter-clockwise to lossen as normal.
I took mine off with an impact wrench. Got one from Lowe's 550 ft lbs. It came right off. I have heard from my friend, Honda mechanic, that some are a bitch. If the impact wrench does not take it off immediately, then you may need a breaker bar and harmonic balancer tool. It is a tool designed to remove the crank bolt while your socket fits inside this bolt. Search for harmonic crank bolt on this site. good luck. Oh, I did a entire write up on changing a timing belt. Let me know and I will send to you. I have a 96 civic and in the process of doing a head gasket replacement....Good luck
Old Nov 29, 2004 | 09:48 PM
hawkmgc's Avatar
Default Re: help...frozen crank pulley bolt (arielb1)
Odd, I got mine off w/o impac.
All I did is lock up the crank by the flywheel (after removing the dust shield), put on a 1/2 wrench, gave it a few good smacks by hand going counter clock wise, and off it came.
The big issue is locking up the ability to have it spin on you. After that the pully came off by hand. Just wiggled it from side to side pulling at the same time. Guess from what I see I was one of the lucky ones.
Good Luck
Old Nov 29, 2004 | 11:15 PM
TOAB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arielb1 &raquo;</TD></TR><TR><TD CLASS="quote">Correct, counter-clockwise to lossen as normal.
I took mine off with an impact wrench. Got one from Lowe's 550 ft lbs. It came right off. I have heard from my friend, Honda mechanic, that some are a bitch. If the impact wrench does not take it off immediately, then you may need a breaker bar and harmonic balancer tool. It is a tool designed to remove the crank bolt while your socket fits inside this bolt. Search for harmonic crank bolt on this site. good luck. Oh, I did a entire write up on changing a timing belt. Let me know and I will send to you. I have a 96 civic and in the process of doing a head gasket replacement....Good luck</TD></TR></TABLE>harmonic balancer pullers work by threading in 3 bolts and then turning a center one to push outward... that pulley does not have 3 holes to plug those bolts in. use a generic puller if it will fit around the outsides.
Old Nov 30, 2004 | 03:18 AM
H-T Order of Merit
Default Re: help...frozen crank pulley bolt (hawkmgc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hawkmgc &raquo;</TD></TR><TR><TD CLASS="quote">
Please don't suggest this without telling them of the possible damage they can cause. Not saying it happens to everyone but it has happened and that enough for me not to do it. For an example of what can happen, look through the link I posted earlier. I posted a link to a thread where this guy used this method and damaged his clutch housing of the tranny. Take a look, there are pictures.
Old Nov 30, 2004 | 03:22 AM
H-T Order of Merit
Default Re: help...frozen crank pulley bolt (TOAB)
Those bolts do come off without using an impact. I've done it three times now.
I use this tool.
http://www.thetoolwarehouse.net/shop/SP-60100.html
This is the tool I believe arielb1 was refering to.
Old Nov 30, 2004 | 06:16 AM
maroonaccord2.2's Avatar
It's a pain. I ended up using a 1/2" breaker bar, and a 4' peice of pipe over the handle to get the thing loose. I had to use a lot of elbow grease though.....
Old Dec 1, 2004 | 07:22 AM
Guru Designs's Avatar
* B A N N E D *
these bolts are known to be a pain in the ***. what works for me every single time i do a timing belt in my shop is a lil heat. torch the WASHER and it should come right out.
Old Dec 1, 2004 | 08:54 AM
seraniko's Avatar
Default Re: (tobe2be)
finally got it out with 1/2" impact after soaking it overnight with liquid wrench....thx for all the help guys.....that tool is a must have if an impact is not available....
Old Dec 1, 2004 | 11:57 AM
miller.91.HB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tobe2be &raquo;</TD></TR><TR><TD CLASS="quote">these bolts are known to be a pain in the ***. what works for me every single time i do a timing belt in my shop is a lil heat. torch the WASHER and it should come right out. </TD></TR></TABLE>
yup!
Old Dec 1, 2004 | 12:24 PM
Schmitey's Avatar
Default Re: help...frozen crank pulley bolt (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">For an example of what can happen, look through the link I posted earlier. I posted a link to a thread where this guy used this method and damaged his clutch housing of the tranny. Take a look, there are pictures.</TD></TR></TABLE>
Alright I'm gonna lose some pride here but you win. Just looked at those pictures and holy **** did he do a number to his crank housing!!! I still think I'd invest the money in a compressor and good gun, but I'm just stubborn.
Also you guys figure it would hurt anthing to run over to a buddy's house, loosen the bolt with his gun, loosely tighten in back up, then drive home to do the rest of the work?
Old Dec 2, 2004 | 03:53 AM
H-T Order of Merit
Default Re: help...frozen crank pulley bolt (Schmitey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schmitey &raquo;</TD></TR><TR><TD CLASS="quote">
Also you guys figure it would hurt anthing to run over to a buddy's house, loosen the bolt with his gun, loosely tighten in back up, then drive home to do the rest of the work?</TD></TR></TABLE>
Probably not. I've heard of others on this board doing that same thing. They didn't seem to have problems so I dought you would.
Old Dec 2, 2004 | 06:40 AM
TOAB's Avatar
just make sure its tighter than your fingers can put it on...
Old Dec 30, 2004 | 07:00 AM
lopster's Avatar
Default Re: (TOAB)
haha I did that and the fking bolt came loose. I heard a clunk and i was like ohh ishht. I got to my house and drove my other car back to look for the bolt and amazingly i found it on the ground in the middle of traffic. lucky my pulley didn't come out.
MurtazaDSM
Mar 2, 2012 11:14 PM
socialistic
31
Jun 26, 2011 12:54 PM
barrera
Oct 11, 2010 07:17 AM
accord2fix
Jun 7, 2004 10:57 PM
Milano97
Jun 2, 2002 04:59 PM
