will itr rear lca's fit (ek)?
Old Nov 29, 2004 | 11:06 AM
hanson said's Avatar
Default will itr rear lca's fit (ek)?
real quick, will itr real lower control arms fit on an ek with stock trailing arms?
to be used with itr shocks, naturally.
Old Nov 29, 2004 | 02:18 PM
Default Re: will itr rear lca's fit (ek)? (hanson said)
anyone?
should i be asking in the itr forum?
Old Nov 29, 2004 | 03:57 PM
marshun's Avatar
Default Re: will itr rear lca's fit (hanson said)
they fit. but you dont need'em
Old Nov 29, 2004 | 03:59 PM
Default Re: will itr rear lca's fit (marshun)
to use itr struts, which have different lower mounting points, i don't need itr control arms?
my main question is: is there a difference in length of the lca?
Old Nov 29, 2004 | 04:01 PM
slammed_93_hatch's Avatar
what the **** this was just addressed the other day. SEARCH MO FO
Old Nov 29, 2004 | 04:06 PM
marshun's Avatar
Default Re: will itr rear lca's fit (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">what the **** this was just addressed the other day. SEARCH MO FO</TD></TR></TABLE>
the dreaded search monster strikes again!
but yeah, you'd get yer answer faster by searching
Old Nov 29, 2004 | 04:11 PM
hayabusa160's Avatar
i dont think it will work because ek lca arms are longer then dc2/eg lca
Old Nov 29, 2004 | 04:16 PM
marshun's Avatar
Default Re: will itr rear lca's fit (hayabusa160)
it works for sure.
Old Nov 29, 2004 | 04:17 PM
jlacoy82's Avatar
71.192.16.183
Dont the EX arms already have holes for rear sways anyways? Couldnt you use a GSR LCA as well?
Old Nov 29, 2004 | 04:53 PM
Default Re: (jlacoy82)
type r uses diffrent shocks in the rear its not the fork style mounting. its like a bushing in the middle. reverse of the normal set up
Old Nov 29, 2004 | 05:00 PM
Default Re: (hayabusa160)
anyways simple search and it will find ur answer and it is NO the ITR LCA will <U>NOT</U> fit in an EK due to the fact that the LCA of an EK is longer then the EG/DC2 ones
source: https://honda-tech.com/zerothread?id=766995
quote by katman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K@man &raquo;</TD></TR><TR><TD CLASS="quote">
NO NO NO!!!!!!
ITR rear LCA's will NOT work on an EK (nor will the fronts). The rears are too short in length and the front LCA's are of different geometry. You have to stick with EK front upper A-arms * LCA's + rear LCA's when converting to 5-lug. The ITR front knuckle+brake assembly and rear trailing arms will bolt up to an EK chassis as long as you keep the EK parts I just mentioned....</TD></TR></TABLE>
case closed thanks
Old Nov 29, 2004 | 05:02 PM
phoshEEzy mahnEEzy's Avatar
Old Nov 29, 2004 | 07:58 PM
Default Re: (phoshEEzy)
thanks to everyone who provided info. case closed.
WilC4
Dec 14, 2009 08:54 PM
Dasanib20T
Suspension & Brakes
Oct 19, 2009 05:20 AM
cnydc2
Feb 26, 2008 07:59 PM
ilovemyb16a
Aug 8, 2007 05:23 AM
lDanny
13
Jun 10, 2004 02:00 PM
