how many Hp will i make w/ my z6
Old Nov 29, 2004 | 10:49 AM
LilCivic04's Avatar
Default how many Hp will i make w/ my z6
i am putting together my z6. it has
wiseco 8.8:1 compression pistons .20 oversize
je rings
scat rods
all clevite bearings
gudes ported head
crower stg 1 turbo cam
skunk2 intake manifold
clutch master stg 4 clutch
fidanza flywheel
turbonetics t3/t4 turbokit
how many horsepower you guys thinkg i will make at 7psi, 14psi, and 18psi? i really dont know how much and i would like you guys to give me a rough estimate. i would like to make atleast 350 at 18psi
Old Nov 29, 2004 | 10:54 AM
dabig1's Avatar
Default Re: how many Hp will i make w/ my z6 (LilCivic04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LilCivic04 &raquo;</TD></TR><TR><TD CLASS="quote">i am putting together my z6. it has
je rings
scat rods
gudes ported head
fidanza flywheel
how many horsepower you guys thinkg i will make at 7psi, 14psi, and 18psi? i really dont know how much and i would like you guys to give me a rough estimate. i would like to make atleast 350 at 18psi</TD></TR></TABLE>
ha,not even close.try 280
Old Nov 29, 2004 | 11:02 AM
RyanEJ8's Avatar
Default Re: how many Hp will i make w/ my z6 (dabig1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dabig1 &raquo;</TD></TR><TR><TD CLASS="quote">
ha,not even close.try 280</TD></TR></TABLE>
You're an idiot. 350whp+ would be a piece of cake at 18 psi with that turbo.
Old Nov 29, 2004 | 11:03 AM
david_rg79's Avatar
umm what turbo do you plan to run???
t3/4 could be any sized turbo
i could see 350hp if you ran a 60trim at 20psi
you also need to specify what fuel managment you plan to run
its not just build motor+boost=hp
there is tons of variables...
Old Nov 29, 2004 | 11:08 AM
LilCivic04's Avatar
Default Re: how many Hp will i make w/ my z6 (david_rg79)
i'm planning to use uberdata, 750cc injectors, and i believe the trim is .57
Old Nov 29, 2004 | 11:09 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david_rg79 &raquo;</TD></TR><TR><TD CLASS="quote">umm what turbo do you plan to run???
there is tons of variables...</TD></TR></TABLE>
A T3/T4 50 trim will make 350whp at about 15-17psi. How do you figure he needs 20psi and a 60 trim???
Old Nov 29, 2004 | 11:13 AM
CivicEJ1's Avatar
my setup below is making over 200HP
Old Nov 29, 2004 | 11:21 AM
yellowturbo's Avatar
Default Re: how many Hp will i make w/ my z6 (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
A T3/T4 50 trim will make 350whp at about 15-17psi. How do you figure he needs 20psi and a 60 trim??? </TD></TR></TABLE>
What is the difference between a 50 TRIM T3/T04E like me with a .60ar compressor and a .63ar turbine AND his 50 TRIM T3T4 ?? Just want to learn... cuz know that I did 335whp at 20 psi... what is the difference between the 2 turbo ??
Old Nov 29, 2004 | 11:26 AM
RyanEJ8's Avatar
Default Re: how many Hp will i make w/ my z6 (yellowturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowturbo &raquo;</TD></TR><TR><TD CLASS="quote">
What is the difference between a 50 TRIM T3/T04E like me with a .60ar compressor and a .63ar turbine AND his 50 TRIM T3T4 ?? Just want to learn... cuz know that I did 335whp at 20 psi... what is the difference between the 2 turbo ?? </TD></TR></TABLE>
You were on a MUSTANG dyno.
I am referring to dynojet numbers that would show about 15% higher than what you have.
Old Nov 29, 2004 | 11:29 AM
ok so there is no difference between a T3T4 and my T3T04E ??? I just try to learn loll
Old Nov 29, 2004 | 11:30 AM
RyanEJ8's Avatar
Default Re: (yellowturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowturbo &raquo;</TD></TR><TR><TD CLASS="quote">ok so there is no difference between a T3T4 and my T3T04E ??? I just try to learn loll </TD></TR></TABLE>
Shouldn't be any major differences.
If you were on a dynojet you would've seen about 390whp.
Old Nov 29, 2004 | 11:36 AM
LilCivic04's Avatar
Default Re: (RyanCivic2000)
would it be good to use 550cc of 750cc? hm.. i am still undecided
Old Nov 29, 2004 | 11:39 AM
If you were on a dynojet you would've seen about 390whp. </TD></TR></TABLE>
I think that I will try to get my car on a dynojet to see those number loll
Thanks for the info ! I cant wait to had more stuff on my engine this winter to get even more on a Mustang dyno !
Old Nov 29, 2004 | 12:27 PM
david_rg79's Avatar
saying 350 on 20psi with a 60trim, gives a safe margin, becasue i had no clue what he was doing for fuel managent, and if he didnt have a way to control timming under boost, he could get significantly lower numbers then others
BTW you can make over 500rwhp on a 50trim (i know from experiance) so your 57trim should do just fine
Old Nov 30, 2004 | 09:28 AM
portenio78's Avatar
Do a search and stay away from the Gude head, trust me!
civintegra
Apr 7, 2009 08:34 AM
rangerxtrn
Jun 25, 2008 05:12 PM
jaydem_ekizzle
Aug 20, 2006 07:52 AM
