anyone running turbo on mini me set up?
Old Dec 30, 2001 | 04:18 PM
civicguy's Avatar
Default anyone running turbo on mini me set up?
i got a6 block and d16y8 head,11:2 comp.any ideas how to get this set up run safely with aleast 5psi?
Old Dec 30, 2001 | 04:37 PM
liam821's Avatar
25 Year Member
Default Re: anyone running turbo on mini me set up? (civic_1.6)
im running 10psi on a stock y7 block with a z6 head....on pump gas. using z6 head gasket..guessing compression is around 9.2:1.
liam
Old Dec 31, 2001 | 04:38 PM
seekerONE's Avatar
not turbo but JRSC
d16a6 block and pistons-stock
d16y8 cylinder head and head gasket
Jrsc using Y8 crank pulley.. boost now at 12psi
Zdyne gold ecu and 440cc injectors
the ecu and injectors are the only way that this will work with pump gas...it allows tuning so fine to avoid detonation
dynoed at 161hp and 138trq...redlined at 6500
daily driven and fun
[Modified by seekerONE, 1:38 AM 1/1/2002]
cevinklark
Dec 31, 2005 07:32 AM
Darkane
Jun 18, 2005 05:42 PM
xXx Justin xXx
Dec 21, 2003 10:54 AM
