HOW DO YOU remove TAR in the trunk and under the rear seats?
Old Nov 29, 2004 | 10:28 AM
eug_34's Avatar
Default HOW DO YOU remove TAR in the trunk and under the rear seats?
I was wondering how I would go about removing the tar that is located in the spare tire area and under the rear seats? I want to gut my rear but that nasty tar is killing me! HELP!
Old Nov 29, 2004 | 10:30 AM
-Gambit-'s Avatar
Default Re: HOW DO YOU remove TAR in the trunk and under the rear seats? (eug_34)
i used some dry ice, and a hammer. place the dry ice on it for a couple seconds then hit it gently with a hammer and it came up. I learned that by searching on honda-tech
JeffS's Avatar
Search the archives of the RoadRace/Autocross forum for the word sound. There are quite a few threads discussing it.
Basically, the easiest thing to do is cool it with some dry ice then it will break right off.
Old Nov 29, 2004 | 10:32 AM
eug_34's Avatar
Default Re: HOW DO YOU remove TAR in the trunk and under the rear seats? (JeffS)
WOW quick replies! I love it! When I use the dry ice... and i scrape it off what would i expect to find under the tar? is it going to be nice and clean like the rest of the body?
Old Nov 29, 2004 | 10:34 AM
-Gambit-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eug_34 &raquo;</TD></TR><TR><TD CLASS="quote">WOW quick replies! I love it! When I use the dry ice... and i scrape it off what would i expect to find under the tar? is it going to be nice and clean like the rest of the body?</TD></TR></TABLE>
it is going to be unpainted, sort of a primer color, but better then having tar there
Old Nov 29, 2004 | 10:47 AM
eghonda's Avatar
Default Re: HOW DO YOU remove TAR in the trunk and under the rear seats? (-Gambit-)
after you pull up the big chunks you can use a solvent like acetone to get rid of the nasty sticky residue. just make sure you're in a well ventilated area
also note that you might strip up paint with the acetone thus calling for the surface to be primered. i primered/painted my hatch shortly afterwards so i was alright.
Old Nov 29, 2004 | 10:56 AM
Built Beast's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Gambit- &raquo;</TD></TR><TR><TD CLASS="quote">i used some dry ice, and a hammer. place the dry ice on it for a couple seconds then hit it gently with a hammer and it came up. I learned that by searching on honda-tech </TD></TR></TABLE>
yeah, this is pretty good info. Just get some dry ice and place it over the area, then I took a long chisel kind of thing(big flat head screwdriver) and tapped it with a hammer....came right up...finished it in like 30 mins.
94lspower
Mar 28, 2007 10:09 AM
Turbo_y8
34
Jan 11, 2006 10:14 PM
NewBorn_EG
11
Oct 4, 2004 09:56 AM
p1ccoloz
Feb 8, 2003 09:29 AM
