Gsr guage cluster
whats up everybody...i was lookin on ebay and saw a crx with a gsr guage cluster and thought that it was pretty cool...i was wondering what would have to be done to make it work in a 89 crx si...will the plugs match up and what else will i need?
Thanks...
Travis
Thanks...
Travis
you need the plugs from the gsr cluster, and you need to cut and spice all the wires from the civic harness to the gsr plugs,
Remove tthe mounting brackets for the old civc cluster and boom. done
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">There are a few threads on this already. </TD></TR></TABLE>
sorry i never thought to check...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox »</TD></TR><TR><TD CLASS="quote">you need the plugs from the gsr cluster, and you need to cut and spice all the wires from the civic harness to the gsr plugs,
Remove tthe mounting brackets for the old civc cluster and boom. done</TD></TR></TABLE>
so all that i have to do is get the wiring diragrams splice the wires together and use new mounting brackets and i am done? the spedometer cable from the crx will plug into the gsr cluster? thanks alot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bigtmanx00x »</TD></TR><TR><TD CLASS="quote">
so all that i have to do is get the wiring diragrams splice the wires together and use new mounting brackets and i am done? the spedometer cable from the crx will plug into the gsr cluster? thanks alot</TD></TR></TABLE>
You also need an electronic VSS ( no more cable )
heres some info I have gathered on the swap.
GSR CLUSTER
https://honda-tech.com/zerothread?id=908882
https://honda-tech.com/zerothread?id=274235
http://www.camsauto.com/crx/103-0388_IMG.JPG
NEWEST LINK!
https://honda-tech.com/zerothread?id=996615
GSR CLUSTER
NEWEST LINK!
trooper0641
17
Apr 28, 2004 10:16 AM
Slow Egg
Mar 13, 2004 07:33 AM
