how hard is it to change your rear left wheel senser for the ABS
free bump, i need to know too... a friend pulled on it while we were doing suspension work and now my ABS light is on...
Should be real easy. Couple small bolts hold the sensor in place, then there's a couple bolts for the brackets that hold the wire, & fish the wire out. Probably the plug is under the carpet at the forward edge of the trunk floor. Or maybe you gotta take the seat out?
Here's a picture from PatrickGSR94... There's an orange plug, top center in the picture. I think that's the left-rear ABS sensor wire.
But... maybe the sensor is corroded into it's mounting at the wheel hub? That can make it a PITA.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLs94Cam »</TD></TR><TR><TD CLASS="quote">hmmm so pull those orange things out?? and they should be there ?</TD></TR></TABLE>Not the sensor... The sensor is at the wheel hub; you gotta take off the brake caliper & rotor, it's almost rubbing against a toothed ring at the hub.
The sensor has a wire which unplugs from the fixed harness at those orange plugs.
b18ccivics
Jul 31, 2005 01:46 PM
