How do I install new springs on my rsx
Old Nov 29, 2004 | 07:38 AM
integraautox's Avatar
Default How do I install new springs on my rsx
Ok, so I just recieved my tein s springs and want to get them on my car. I am pretty good when it comes to working on cars, well at least when I had my integra. Any ways is the spring install pretty much strait forward or is there anything I need to look out for. Some one told me something about drilling into the bottom of the strut but I have never had to this on any of my other cars. Thanks in advance.
Old Nov 29, 2004 | 10:15 AM
Boilermaker1's Avatar
No drilling. That sounds like a Koni install.
Take the struts out of the car (3 bolts up top, 2 on the knuckle and the tie rod), remove the upper hat, swap the spring, reassemble. Make sure you tie the brake assembly up with something so the axle doesn't fall out of the transmission when you unbolt the strut. The rears are straight forward also.
Old Nov 29, 2004 | 10:22 AM
whiteDCfiver's Avatar
Default Re: (Boilermaker1)
ya make sure the axle doesnt fall out. Its a bitch to put back in.
Old Nov 29, 2004 | 10:36 AM
t o m's Avatar
Default Re: (whiteDCfiver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteDCfiver &raquo;</TD></TR><TR><TD CLASS="quote">ya make sure the axle doesnt fall out. Its a bitch to put back in.</TD></TR></TABLE>
yes dont forget to tie it up.
Old Nov 30, 2004 | 05:19 AM
Todd00's Avatar
I said I don't want a title!
Default Re: How do I install new springs on my rsx (integraautox)
A quick search on google found this:
http://www.k-series.com/tech_d...RINGS
Old Nov 30, 2004 | 06:39 AM
-slow ej-'s Avatar
^^^ that is sooo true...
Old Nov 30, 2004 | 06:21 PM
RsxVengeance's Avatar
http://www.clubrsx.com
Old Nov 30, 2004 | 07:54 PM
S-fiend's Avatar
Default Re: (RsxVengeance)
The rear bolt can be a pain in the *** to get off and on. But besides for that its straight forward.
Old Dec 1, 2004 | 08:15 PM
kseriesDC5's Avatar
Default Re: (S-fiend)
My axle popped out just a couple turns and it was back in so keep it up with like a jack or something, for the back you need to adjust a lot so u can get the bolt through. I used a giant crow bar to pry up the arm to make the hole line up.
Old Dec 1, 2004 | 09:02 PM
k-cerez's Avatar
Default Re: (kseriesDC5)
man i thought my car was fucked when the axle fell out but got it back in a few turns
TOO MUCH TORQUE
Dec 29, 2010 12:47 PM
jnellie11
Aug 23, 2005 10:39 PM
Unjockable
15
Apr 15, 2005 05:15 PM
STHPERFORMANCE
May 8, 2003 08:12 AM
