gsr rods on a ls crank????? is it possible without machining????
Old Nov 29, 2004 | 04:28 AM
electric_rex's Avatar
Default gsr rods on a ls crank????? is it possible without machining????
i just bought gsr rods and pistons how hard would it be to stick them in a ls block with a gsr crank...... is there any machining that needs to be done or should i just buy a gsr block...... would there be a bad effect on the stroke i dont know if the ls rods have bigger journals or not.
Old Dec 5, 2004 | 11:41 AM
Default Re: gsr rods on a ls crank????? is it possible without machining???? (electric_rex)
ttt
Old Dec 5, 2004 | 02:57 PM
Dragline's Avatar
Are you putting GSR rods in an LS block with LS crank or GSR rods,pistons & crank in a LS block.
carlossolorzano
May 27, 2012 01:12 AM
NathanMorris
Nov 30, 2004 10:01 AM
B18C-EJ1
Jan 19, 2002 11:45 PM
