5th Gen Temperature Knobs Loose/Broken?
Well to be specific my hot/cold temperature **** is loose now. I cant seem to find out what happened. When I try to turn the **** know i feel there is no resistance and there is nothing turning except the **** except. Usually I would feel that I would be turning something sort of rough but now theres no resistance. Could it just be that the **** fell out of its joint or something? I hope I dont have to replace this whole set. What might be wrong?
Found out it was the plastic covering the metal piece snapped somehow. I will stop by Honda this week to buy one. I need to defroster for my car or else I'm blind =[ Especially in the winter time
just keep some needle nose pliers in the car to turn the **** lol...thats what i did for a little bit. the **** only fits on one way so there no need to worry about messing up where its suppose to be
You can get them here for $7
http://www.secureleadercom.com...block
Of course with shipping it'll be more so you're probably better off going to Honda.
the honda dealer i go to sells a little metal piece to slip over the end of the **** so it doesn't break. http://www.hondabarnnissan.com
-pull the **** out
-put some super glue on the broken tip
-put a strip tie around the tip to prevent the **** from breaking again and also to reinforce it (use a pair of pliers to pull the strip tie to make it tight)
im also cheap!
