D16Z6 --> D16Y8 Swap...
Old Nov 28, 2004 | 09:16 PM
dw.VTEC's Avatar
Default D16Z6 --> D16Y8 Swap...
Just wanted to learn more about the swap of this motor. I don't know alot about the ODB stuff and I'm not sure on the trannys either. I'd like to keep my stock tranny on the Y8. Thanks for all your help...
*EDIT* Swap is being done in a '93 del Sol Si, Y8 is from a 97 Civic EX...
Old Nov 28, 2004 | 09:26 PM
cnyej1's Avatar
Default Re: D16Z6 --> D16Y8 Swap... (NEONBOY)
Why u doing the swap..... its pretty pointless unless your motor is blown
Old Nov 28, 2004 | 09:29 PM
dw.VTEC's Avatar
Default Re: D16Z6 --> D16Y8 Swap... (cnyej1)
Motor is high mileage, the Y8 is cheap, B-series not in my budget...
Old Nov 28, 2004 | 09:35 PM
stormy's Avatar
I would say you just go d15b vtec for 400 bux but if the motor your getting is alot cheaper just use the head and block and swap over your and EM all wiring ect and your injectors and dizzy
Old Nov 28, 2004 | 09:46 PM
Andres-eh2's Avatar
[FAQ] What swaps are available for my Civic?
https://honda-tech.com/zerothread?id=878010
Read up and then post if you cannot come to a decision or have a technical problem
s4yama
Apr 23, 2011 02:54 AM
byc_cb7
26
Aug 7, 2009 06:50 AM
gizzm619
May 13, 2009 10:51 PM
PoWeRBaN_PaNdA
Mar 29, 2004 06:00 PM
