Busted Tension Pin in rear drums of CRX
Old Nov 28, 2004 | 08:13 PM
T--Rex's Avatar
Default Busted Tension Pin in rear drums of CRX
I was replacing my rear drums and one of the 2 small tension pins broke off, i was just wondering what will happen if i only have on in place. It seems as if it's purpose is just to hold the shoes in place. However, It doesn't seem to have any whare it can move to because of the springs holding it in place. Has anyone else done this, do you think it will be a problem.
Old Nov 28, 2004 | 08:41 PM
Cory man's Avatar
Default Re: Busted Tension Pin in rear drums of CRX (Matrix_Zero)
You are correct the pin DOES hold the shoe in place. Good luck getting your drums off next time. No pin=drum wont come off.
Old Nov 28, 2004 | 10:24 PM
RCautoworks's Avatar
Wait what pins are we talking about. The only ones that really hold the shoe to the backing plate are the 2 that go threw the show, those are a must.
What number are you talking about ?
Old Nov 29, 2004 | 04:22 AM
T--Rex's Avatar
Default Re: Busted Tension Pin in rear drums of CRX (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Wait what pins are we talking about. The only ones that really hold the shoe to the backing plate are the 2 that go threw the show, those are a must.
What number are you talking about ?</TD></TR></TABLE>
#38 is the tension pin, it connects to #37
Old Nov 29, 2004 | 05:08 AM
EJ2-Fluffy's Avatar
heh, ur drums wont work because nothing will be holding it together =\
Old Nov 29, 2004 | 09:02 AM
T--Rex's Avatar
Default Re: Busted Tension Pin in rear drums of CRX (CRX-Fluffy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX-Fluffy &raquo;</TD></TR><TR><TD CLASS="quote">heh, ur drums wont work because nothing will be holding it together =\</TD></TR></TABLE>
Are you sure, because the springs and drums will still hold the shoes in place. It just has no whare to go, once the brakes are pressed the shoes have no whare to go but to press against the drums. Or am i missing something?
Old Nov 29, 2004 | 09:20 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matrix_Zero &raquo;</TD></TR><TR><TD CLASS="quote">
Are you sure, because the springs and drums will still hold the shoes in place. It just has no whare to go, once the brakes are pressed the shoes have no whare to go but to press against the drums. Or am i missing something?</TD></TR></TABLE>
Well then go and try it and don't come crying to us with a "car wouldn't stop, hit a pole" thread later.
Old Nov 29, 2004 | 09:42 AM
Default Re: Busted Tension Pin in rear drums of CRX (EL Vap133)
Just go to autozone or pepboys and by the spring return kit, there is no way the shows are gonna hold.
Old Nov 29, 2004 | 10:09 AM
johnzm's Avatar
theres a force at the top of the shoe presssing it into the drum. without that pin there, the shjoe will just rotate around in the drum and wont exert much force at all..
Old Nov 29, 2004 | 10:11 AM
HatchBox's Avatar
Skoobie no more...
time for a rear disk swap
Old Nov 29, 2004 | 10:54 AM
crxgator's Avatar
Default Re: Busted Tension Pin in rear drums of CRX (HatchBox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">time for a rear disk swap </TD></TR></TABLE>
for real, i changed drums once and i will never do it again...too much aggravation, where as if it was rear disk, bam done in 20 mins...
Old Nov 29, 2004 | 11:29 AM
T--Rex's Avatar
Default Re: Busted Tension Pin in rear drums of CRX (crxgator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">
for real, i changed drums once and i will never do it again...too much aggravation, where as if it was rear disk, bam done in 20 mins... </TD></TR></TABLE>
Yeah, i guess that is what i will do... i have been looking to do the swap for a while, i just never had a reason to.
Old Dec 2, 2004 | 09:56 AM
EJ2-Fluffy's Avatar
Hehe Pmd ya
-Jon
Old Dec 2, 2004 | 10:11 AM
T--Rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX-Fluffy &raquo;</TD></TR><TR><TD CLASS="quote">Hehe Pmd ya
-Jon</TD></TR></TABLE>
Nope
MrPotatoeHead
Nov 23, 2005 12:17 PM
ERIC!
Nov 21, 2005 08:19 PM
Mag00n
Honda Motorcycles
Jun 30, 2005 08:59 AM
ILOVEGIRLS
Jan 3, 2004 08:20 AM
JDMBOLONI
14
Apr 22, 2003 08:29 AM
