SOHC headgasket issues and dowel height size?
taken from Sonny's engine build site
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">These are the dowel pins that locate the head onto the block. This is an often overlooked area that can cause a lot of headaches. Since the head now sits closer to the block (about .030" closer due to decking/milling), I also shortened the dowels by the same amount. In some cases, failure to due this will result in a headgasket leak since the dowels will not allow the head to fully touch the block. </TD></TR></TABLE>
just wondering if people do shorten these dowels, when resurfacing the head or block?
i myself never thought of that and with all the blown headgasket problems, it sounded worthwhile
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">
i myself never thought of that and with all the blown headgasket problems, it sounded worthwhile</TD></TR></TABLE>
If milling the head I would definately shorten the dowels. SOHC heads have enough problems sealing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">If milling the head I would definately shorten the dowels. SOHC heads have enough problems sealing.</TD></TR></TABLE>
bump
lets see if this helps some turbo SOHC
bump
i did this with my setup and still blew a head gasket.
not saying this will not help for some people if there head is milled .020 +.
i guess i just had other issue's.
platinum.
platinum.
walkerklondyke2000
Jan 12, 2006 10:11 PM
3rdGteg
12
Sep 29, 2003 08:00 PM
