While re-installing my front seats I think I may have stripped a bolt... help.
Old Nov 28, 2004 | 04:12 PM
RuskeR's Avatar
Default While re-installing my front seats I think I may have stripped a bolt... help.
While installing my system this weekend I had to remove the front seats. I had a buddy of mine put the passenger seat back in and I guess he cross threaded the first few threads of the bolt.
I couldn't get it to go in without it feeling tight like it wasn't going in correctly. I tried using a "good" bolt I had to see if that was the problem but it also would feel like it wasn't going in correctly. I tried just leaving it out with the other 3 bolts in but the seat rocked. So, I just wrenched it down.
When I eventually pull the seat out again I'm afraid it won't go back. Can the mounting point be fixed? Retapped?
Anyone run into this problem?
Old Nov 28, 2004 | 05:22 PM
Lewie's Avatar
I'm here for the gangbang!
when i helped my buddy w/ his seats, he only had 3 bolts on one and the seat was fine, i'm surprised that yours is rocking. if you have any problems when you pull it out next, try using a self tapping screw.
Old Nov 28, 2004 | 05:26 PM
CleanLikeJdm's Avatar
Hype-R Stalker
I dunno about a self tapping screw, that would probably just mess the threads up more. I would just try getting the tap, they usually go for 5-15 i think.
PreyStayShun
Nov 26, 2011 05:07 PM
square_1
Dec 11, 2006 02:18 AM
goldhatchie89
Welding / Fabrication
Aug 30, 2006 07:22 AM
Dan Fizzle
Jun 1, 2006 08:56 PM
black00civicsi
Apr 8, 2005 09:40 PM
