Here it is, B18a/b, B20b/z Aftermarket cam list and specs!
Old Nov 28, 2004 | 02:47 PM
hybrid_vtec's Avatar
Default Here it is, B18a/b, B20b/z Aftermarket cam list and specs!
Sorry it took me so long to get up all of this information, but I was waiting for replies for the manufacturers! Hopefully AllMotorMark will update his website with this information!
http://www.allmotorhonda.com
* I would like to thank eveyone that donated their information to this and to AllMotorMark for adding a non-vtec section to his site*
<FONT SIZE="2">Nonvtec Cams: B18A/B, B20B/Z</FONT>
STOCK B18B:
Intake: 185 degrees @ .050, Lift: .395
Exhaust: 187 degees @ .050, Lift: .380
CROWER CAMS:
http://www.crower.com
62403:
Duration @ .050: 211/210, Lift: .423/.409
Lobe Seperation: 110 degrees
62404-2:
Advertised Duration: 308/305, Lift: .445/.434
Duration @ .050: 226/224, Lift: .254/.248
Lobe Separation: 109 degrees
Valve Clearances: .006/.008 (Cold)
62405:
Intake..... 502 lift @ 252 duration @ .050"
Exhaust ...502 lift @ 252 duration @ .050"
62405a:
Intake..... 476 lift @ 230 duration @ .050"
Exhaust... 467 lift @ 222 duration @ .050"
Recommended Valvesprings:
Part# 68181 Dual Springs
Approx Spring Pressure:
Valve closed: 060/070 LBS.
Valve open: 155/165 LBS.
CRANE CAMS:
http://www.cranecams.com
101-0012:
Advertised Duration: 232/250, Lift: .400/.388
Duration @ .050: 206/212
109 degrees lobe seperation
101-0014:
Advertised Duration: 232/242, Lift: .400/.388
Duration @ .050: 206/204
Lobe Separation 111
101-0016:
Advertised Duration: 246/246, Lift.433/.433
Duration @ .050: 218/218
Lobe Separation 108
101-0018:
Advertised Duration: 254/254, Lift: .453/.453
Duration @ .050: 226/226, Lift: .250/.250
Lobe Seperation = 104
Valve Clearances: .004/.008 (cold)
101-0020:-Advertised Duration = 262/262 degrees, Lift: .472/.472
-Duration @ .050" = 234/234
-Lobe Seperation = 108
Part# 903-2000 Dual Springs
Valve closed: 042/042 LBS.
Valve open: 152/152 LBS.
EXOSPEED:
http://www.exospeed.com
LS909:
Duration @.010 268/254 Lift 400/388
* does not require valvetrain.
* powerband is 3000-7600 RPM
RACE LS:
Duration @.010 268/268 Lift 400/400
* Requires valvetrain upgrade if taking it past stock Rev limit.
* powerband is 3000-8000 RPM
STAGE 4 RACE: (FOR SERIOUS RACERS ONLY)
COLT CAMS:
http://www.coltcams.com
LS RACE CAMS:
Intake: duration = 264, Lift: .423
Exhaust: duration = 264, Lift: .423
LS RACE CAMS:
Intake: duration = 278, lift = .432
Exhaust: duration = 278, lift = .423
JG ENGINE DYNAMICS:
http://www.jgenginedynamics.com
*Valve Clearances for JG Cams(ALL): Intake: .007, Exhaust: .009
3030:
Intake: 250 degrees, Lift: .385
Exhaust: 250 degrees, Lift: .385
1001:
Intake: 260 degrees, Lift: .410
Exhaust: 260 degrees, Lift: .410
301:
Intake: 274 degrees, Lift: .417
Exhaust: 260 degrees, Lift: .408
303:
Exhaust: 274 degrees, Lift: .417
6050:
Intake: 280 degrees, Lift: .442
Exhaust: 274 degrees, Lift: .425
Web Cams:
http://www.webcaminc.net/
#148E:
Duration @ .050: 210/210 degrees, Lift: .395/.390
#115:
Duration @ .050: 222/222 degrees, Lift: .395/.395
#452:
Duration @ .050: 228/228 degrees, Lift: .410/.405
Modified by hybrid_vtec at 3:57 PM 11/28/2004
Old Nov 28, 2004 | 02:54 PM
PirateMcFred's Avatar
Default Re: Here it is, B18a/b, B20b/z Aftermarket cam list and specs! (hybrid_vtec)
Sweet!
Old Nov 28, 2004 | 04:51 PM
AllMotorMark's Avatar
thanks i'll get right on it
Old Nov 29, 2004 | 10:27 AM
Default Re: Here it is, B18a/b, B20b/z Aftermarket cam list and specs! (AllMotorMark)
bump
Old Nov 29, 2004 | 12:00 PM
arw321's Avatar
Good job.
One correction:
The less agressive grind by Colt is called their "street grind".
HTH,
Adam
Old Nov 29, 2004 | 03:47 PM
Default Re: Here it is, B18a/b, B20b/z Aftermarket cam list and specs! (arw321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arw321 &raquo;</TD></TR><TR><TD CLASS="quote">Good job.
One correction:
HTH,
Adam
Thanx!
akurtzer57
Jan 4, 2010 01:25 PM
electric-boost
Feb 18, 2008 07:53 AM
pauld
Jun 22, 2007 12:56 PM
random-strike
Nov 11, 2003 02:13 PM
Forgiven
Sep 24, 2003 11:18 AM
