DPFI 2 MPFI resistor box wiring
Old Nov 28, 2004 | 02:42 PM
shivern's Avatar
Default DPFI 2 MPFI resistor box wiring
Im just lookling for a clearer picture on how to do this -- i've searched thoroughly and gone to all the sites on dpfi to mpfi swaps ...
now tell me if im wrong..
You take the 4 solid black wires coming from the injector resistor box and sodder them to the 4 wires coming off the injectors (which are red / black), then with the last wire on the resistor box (which is solid red) , you sodder it to the to the 2 original yellow/black wires from the original harness.
IS THIS CORRECT?
Old Nov 28, 2004 | 03:07 PM
Rywire's Avatar
Default Re: DPFI 2 MPFI resistor box wiring (shivern)
You got it man!!
Ryan
Old Nov 28, 2004 | 03:12 PM
shivern's Avatar
Default Re: DPFI 2 MPFI resistor box wiring (droppedcrxsi)
so thats a yes you sodder the two yellow/black wires to the one red wire on the resistor box..
Old Nov 28, 2004 | 03:13 PM
cbp_crx's Avatar
yes you are correct
Old Nov 28, 2004 | 04:16 PM
shivern's Avatar
Default Re: DPFI 2 MPFI resistor box wiring (crx_si6)
Old Nov 28, 2004 | 05:07 PM
shivern's Avatar
is there a reason why u have to solder both of the yellow / black wires to the one on the resistor box?
why cant u just solder one
Modified by shivern at 7:45 PM 11/28/2004
Old Nov 28, 2004 | 08:51 PM
Rywire's Avatar
Do em both, thats what I always do, and it works fine. DONT ASK QUESTIONS, DO IT NOW!!! HAHAHAHAH
Ryan
markgo
Nov 8, 2006 11:39 AM
Dunc
Oct 2, 2005 02:12 PM
integramic
May 24, 2005 10:27 AM
TYPErCRX
Feb 28, 2005 03:27 AM
DOHClessEF-9
Feb 5, 2005 04:35 PM
