rings on forged pistons does it take longer for them to seat
Old Nov 28, 2004 | 12:34 PM
ghettochild's Avatar
Default rings on forged pistons does it take longer for them to seat
i just put in a set of 9 to 1 forged pistons in my gsr block and they still have not seated. my motor smokes only when i down shift or get on it, is that the rings not seated or is it in the head. the block has been hoaned etc.. any advice would be great
thanks
Old Nov 28, 2004 | 01:29 PM
mmuller's Avatar
Mad Scientist
Default Re: rings on forged pistons does it take longer for them to seat (ghettochild)
how many miles?
Old Nov 28, 2004 | 03:21 PM
drdisco69's Avatar
Default Re: rings on forged pistons does it take longer for them to seat (mmuller)
And how did you break it in?
v4lu3s's Avatar
RTFM
how many miles and how did you break it in, and what oil did you use during breakin?
Old Nov 28, 2004 | 03:29 PM
Denny Crane's Avatar
If you're deceling on the downshift (just wanted to be sure, considering some of the info witholdingness on some of the threads), it's valve guides and/or valve guide seals. Blue smoke on accel is oil rings (after the first few seconds). A piston with excessive rock can also do this. What ptw clearance are you running?
Old Dec 10, 2004 | 04:51 PM
Default Re: rings on forged pistons does it take longer for them to seat (Denny Crane)
its a black smoke and leaves black **** on the back of my hatch. so im thinking valve seals, because i did a comp test and its 150 all across. so hopefully its the valve seals because i already bought another head and this one im giving it a valve job. i just throught this head on not looking it over or anything.
and i have 1700 miles on the motor so far
Old Dec 10, 2004 | 10:31 PM
msmotorsports's Avatar
If its a black smoke it sounds like your too rich. Excess fuel burns black while oil burns white/blue.
Old Dec 10, 2004 | 10:49 PM
JBBNJ609's Avatar
Default Re: rings on forged pistons does it take longer for them to seat (msmotorsports)
did you tune your car ???
gimme some more info on your setup
Old Dec 11, 2004 | 04:17 AM
v4lu3s's Avatar
RTFM
and excess rich means you probably washing the cylinder walls down with gasoline and probably will never have the rings seat if its been like that since day 1.
mrgar
Sep 15, 2009 09:37 PM
ianp3k
Apr 24, 2008 12:05 PM
Chuji
Aug 19, 2003 02:06 PM
1.8T_EG
Oct 21, 2002 12:50 PM
