Need help on wiring gauges for DC2!!
Old Nov 28, 2004 | 10:18 AM
kcjohnnyboy's Avatar
Default Need help on wiring gauges for DC2!!
I'm wiring up my A/F, Boost, and Oil Pressure Gauge in my car and wanted to get some extra help on a little thing.
The picture below is the fuse box/relay under the dash of a DC2. I have an illumination, ignition, and 12v battery wires. Which of the four numbered spots do I hook up those wires. Thanks a lot...
Old Nov 28, 2004 | 02:23 PM
fcm's Avatar
fcm
Old Fart
Default Re: Need help on wiring gauges for DC2!! (kcjohnnyboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kcjohnnyboy &raquo;</TD></TR><TR><TD CLASS="quote">I'm wiring up my A/F, Boost, and Oil Pressure Gauge in my car and wanted to get some extra help on a little thing.
</TD></TR></TABLE> You will have to test to be sure, as they change from year to year and model to model,There is no true ign., it is a 2nd ign., [no power when cranking] 94
Old Nov 28, 2004 | 04:58 PM
anyone else can help me out please?
Old Nov 28, 2004 | 09:34 PM
integra-modder's Avatar
email me at poldim@comcast.net
ill be in the states tomorrow and can look at my helms then
Old Nov 28, 2004 | 10:00 PM
Default Re: Need help on wiring gauges for DC2!! (integra-modder)
i will email you tonight...thanks
Old Nov 29, 2004 | 04:18 PM
SlowTeg's Avatar
Buy a test light and figure it out yourself. It's VERY easy. A test like is &lt;$5 and is a good investment.
-Mike
Old Nov 29, 2004 | 06:36 PM
Default Re: Need help on wiring gauges for DC2!! (SlowTeg)
thats the problem, im not familiar with a test light... i guess i would just have to search and see how to use it...thanks man
Old Nov 29, 2004 | 08:26 PM
SlowTeg's Avatar
Sorry, maybe I should have explained a little.. A test light is just a light that turns on when it has enough voltage.. You ground the wire for the bulb and touch the probe at the source where u question if there's power or not. So... simply ground the test light wire, then switch the parking lights on, touch the different leads, one should light up.. then turn off the parking lights and touch the same lead.. if it doesn't light up anymore that's ur switched +12v parking light source. You can obviously do that same thing to test for switched +12v ignition, except turn the key on and off to trigger the power.
Test lights are very cheap and can be found at advance auto parts, etc. and can be very handy. Let me know if you got any questions. Hope that helps.
-Mike
Old Nov 30, 2004 | 07:22 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowTeg &raquo;</TD></TR><TR><TD CLASS="quote">
-Mike</TD></TR></TABLE> Ditto that, but a multimeter is a better bet, and are also cheap.
A multimeter will let you do a lot more, like testing speakers checking for shorts, and many more things, if you are planing to do work on your car yourself, get a multimeter, it will pay for itself in no time, one more thing about a testlight, [I have one and use it every day] be very carefull how you use it, around the fuse box or batt. and anything that you know should be 12vdc it's ok, but stay away from anything that has anything to do with ECUs, BCMs, GEMs, or any other computers in your car, a test light can DAMAGE them, evan the LED "safe" testlights. A multimeter will not. 94
Old Nov 30, 2004 | 08:21 AM
SlowTeg's Avatar
Default Re: Need help on wiring gauges for DC2!! (fcm)
I agree, a multimeter is definetly better, but a test light is usually like 2-3$, very cheap, and is perfect for looking for a ground or power source for these sort of situations. If you're in awkward positions where u cant hold the multimeter readout to see it, a testlight is must simpler because it lights up in front of your face. Test light is incredibly useful for the $.
-Mike
Old Nov 30, 2004 | 11:38 AM
thanks slowteg...that helps alot...
Old Dec 1, 2004 | 12:38 AM
This is for the 98 + but I think the 94-97 is the same
freom left to right they are ports 1,2,3,4
1 - +12 from battery
2 - +12 when dash lights are on
3 - +12 with ignition key in ACC position
4 - +12 with key in ignition position
Old Dec 2, 2004 | 02:30 PM
thanks...helps a lot...now time to put the gauges in...
kcjohnnyboy
Nov 30, 2004 02:02 PM
kcjohnnyboy
Nov 30, 2004 01:53 PM
kcjohnnyboy
Nov 28, 2004 05:01 PM
Sprockets
Oct 27, 2004 08:59 PM
SPOON_BeIgHtEeNsEe
Oct 29, 2001 05:28 AM
