intake/battery help...
I'm currently building a 1990 si hatch with a b18a1 and my buddy gave me his aem cold air of his ek coupe. there's currently no battery and it looks like there's not gonna be enough room for a battery. I can either buy a brand new intake for the ef, relocate the battery, or try to find a smaller battery from another car or a race battery. Which do you think would be more cost effective and/or performance oriented? Keep in mind that i'm 18 year old full time student with a limited budget...thanks for any help you can give me.
put the battery in the back...
in a fwd its not really good to put weight in the back but sometimes u have no choice... meh..
its simple for the most part. battery box, extended battery cables, 100amp for the power wire that will splice into 3 different wires for starter power, ecu..
more info on http://www.fourthgenhatch.com he did some stuff with the relocating that isint totally neccessary but they were good moves and he did some preety clean **** in his day.
Hawker EP13 vs. Stock size lllllll -10lbs vs. 30+lbs
<U>Batterymart.com</U> has a good price on this
yeah, relocate it. I did mine and re-did all the grounds with the extra power wire I had. After the grounds were replaced I noticed a big difference.
i have the same engine and the same problem with the air intake , the tube basically sits right on top or on the side of the pos. post . im goin to relocate the battery soon but for now just have a big red terminal cover between the post and the intake tube , not the safest thing but will work for a little while
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c »</TD></TR><TR><TD CLASS="quote">relocate the battery. It's about $25 worth of stuff and it takes less than a 1hr to do. Then you can get any intake you want.
</TD></TR></TABLE> 25 dollars? Thats alot to just move ur battery a few feet. I paid 2 bucks for the gold connectors and went to a stereo shop and got the biggest wire they had. i think it was 4 guage.
I think it's either summit racing or jegs that sells different relocation kits between 50 and 100 dollars. The kits come with wiring, battery box, and hardware.
Be like my friend and put the battery on the floor on the passenter side :D. Fairly cheap to do the relocation, and it was a great conversation piece.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MattP »</TD></TR><TR><TD CLASS="quote">Typically 00, 0, or 1 gauge wire is used for this. 4 gauge is just asking for an electrical fire. Summit racing has a pretty nice setup for battery relocation.</TD></TR></TABLE> why would 4awg cause a fire?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELAMINT5 »</TD></TR><TR><TD CLASS="quote"> why would 4awg cause a fire?</TD></TR></TABLE>
The 4awg having too much current drawn through it therefor causing it to heat up......hmm...****, my battery is being used with 4!!
But in the 6 months it has been back there with proper fusing I have yet to cause any fires, and I am using the mini battery.
Balogne! If you notice, the wire that goes to the starter is 8 gauge. 4 gauge is plenty. Afterall, you aren't starting the car the whole time you're driving it. Happy holidays everybody.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikerbike »</TD></TR><TR><TD CLASS="quote">Balogne! If you notice, the wire that goes to the starter is 8 gauge. 4 gauge is plenty. Afterall, you aren't starting the car the whole time you're driving it. Happy holidays everybody. </TD></TR></TABLE>
But that wire is kept at ~1.5ft while a run to the hatch (in my case trunk) is much longer. Longer wire, more resistence.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 »</TD></TR><TR><TD CLASS="quote">until you crash and the battery goes flying into your nads...
Agreed
. Just lately he re-wired it into the hatch, but then his transmission blew
, so we never really got to test it.
</TD></TR></TABLE>Agreed
Does the Summit Kit come with 0AWG? I thought it only came with 4AWG. Please correct if I am wrong bt isn't a battery only used when a) to start the car; b) when the alternator dies; c) if the car is off and you have the key to the on or acc position?
