Oil and filter change intervals on a 2004 Accord
Old Nov 28, 2004 | 09:06 AM
carguy2k's Avatar
Default Oil and filter change intervals on a 2004 Accord
The owners manual states that the oil is to be changed every 10,000 miles and the filter every 20,000. Am I missing something here, or is this a misprint. My daughters 2004 has 8,500 miles on it and the maintenance light is coming on. I am an old school mechanic and believe in 3,000 mile oil and filter changes as cheap insurance. With this in mind even though the car uses the lightweight oil 5w-20w, wouldn't it be better to change the oil and filter frequently every 3k to 4k.
Old Nov 28, 2004 | 09:10 AM
sj993's Avatar
Default Re: Oil and filter change intervals on a 2004 Accord (carguy2k)
Yes, the owner's manual for my '94 states to change it every 7,500 miles. Doing it at those intervals I'd be doing an engine flush everytime. I'm with you on doing it every 3K.
Old Nov 28, 2004 | 09:16 AM
f23accord's Avatar
Default Re: Oil and filter change intervals on a 2004 Accord (sj993)
As am I with you on changing the oil every 3k-3.5k, better safe than sorry...plus i like to spoil my car using mobil1 super synthetic, my car loves it
Old Dec 1, 2004 | 12:43 PM
Heat's Avatar
Default Re: Oil and filter change intervals on a 2004 Accord (f23accord)
My owner's manual for my '99 has an oil change every 7,500 miles, and a new filter every 15,000 miles.
I dunno, it just doesn't sound right. I give my car an oil change every 3,500 to 4,000 miles by myself (Castrol GTX, Fram filter).
Old Dec 1, 2004 | 01:02 PM
Beach Accord's Avatar
i change my oil with castrol gtx 5w-30 every 2500-2800 miles.
utilizing toyo roki honda OEM filters made in japan too (S2K)!
please stay away from oil additives and engine flushes.....more like gasket eaters....
honda states specifically NOT to use oil additives.
Old Dec 1, 2004 | 02:40 PM
Heat's Avatar
Default Re: (Beach Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beach Accord &raquo;</TD></TR><TR><TD CLASS="quote">
...</TD></TR></TABLE>How much are OEM filters? I know that the Fram filters I use aren't that good, but they are cheap ($3). Also, anyplace to buy OEM filters in bulk for a discount?
Old Dec 1, 2004 | 02:52 PM
sj993's Avatar
Default Re: (Heat)
They cost me around $3 a filter... of course that's wholesale.
Old Dec 1, 2004 | 03:11 PM
Default Re: (Heat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heat &raquo;</TD></TR><TR><TD CLASS="quote">How much are OEM filters? I know that the Fram filters I use aren't that good, but they are cheap ($3). Also, anyplace to buy OEM filters in bulk for a discount?</TD></TR></TABLE>
i get my filters at employee pricing thanks to friends in the parts dept.
they run me about 4.50 a piece but are well worth it.
stay away from fram. if you cut one open you will see how garbage they really are.
at least get purolator PUR one if you are going to buy aftermarket.
Old Dec 8, 2004 | 08:22 AM
SnJ's Avatar
SnJ
We have an 02 Accord V6. Running Pennzoil 5W-20, adding a little Lube Control to reduce oxidation and a little Schaeffer's 132. Honda OEM filters, now using the PCX-004. Did a used oil analysis this summer, about 45K miles on the car, 4700 miles on the oil. Wear metals were very low and viscosity was well in grade. We do 70% highway driving. Running this current change out to 6000 miles +/-.
Running a good oil and maintaining the car well, OCI of 4-6 K miles should make sense, combo of highway/city driving. If you're running a lot of city miles, car doesn't get warmed up much, then you might consider changing sooner.
A number of UOAs show that Hondas do just fine on 5W-20 oil. Lost more info at http://www.bobistheoilguy.com
Old Dec 8, 2004 | 11:50 AM
matt_in_sd's Avatar
Not to shake peoples faith in the church of jiffy lube, I used Mobile1 for the last 150,000 miles and I change the oil about 25k - 30k. My '99 Accord has only 190,000 on it so it is still to early to tell if I am killing it.
Old Dec 8, 2004 | 01:07 PM
sj993's Avatar
Default Re: Oil and filter change intervals on a 2004 Accord (matt_in_sd)
Wow. I use Mobil1 as well. Have for about 50K now and I still change it every 3-4K.
Old Dec 8, 2004 | 03:11 PM
Shinbo's Avatar
my dealer gave me free oil changes until 100,000k miles on my 04 accord, but they only let me get it at the dealer every 5k miles. so i was assuming that changing it at every 5k was ok.
Old Dec 8, 2004 | 04:20 PM
Default Re: Oil and filter change intervals on a 2004 Accord (Shinbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shinbo &raquo;</TD></TR><TR><TD CLASS="quote">my dealer gave me free oil changes until 100,000k miles on my 04 accord, but they only let me get it at the dealer every 5k miles. so i was assuming that changing it at every 5k was ok.</TD></TR></TABLE>
i had the same incentive given to me when i purchased my accord.
however, i was friends with the service manager and service writers so i took mine in every 2500 miles....
:duff man voice: OH YEAH!
Old Dec 9, 2004 | 12:27 AM
Shinbo's Avatar
Default Re: Oil and filter change intervals on a 2004 Accord (Beach Accord)
:duff man voice: OH YEAH!</TD></TR></TABLE>
lucky...
Old Dec 9, 2004 | 05:25 AM
KGAccord's Avatar
fyi, the canadien made honda filters are made by fram. though i never had a problem with them and i used them for years. my oem subaru filter is made by toyo roki now
as for the 7,500 -10,000 mile oil changes it says in the honda manual it will also under "sever conditions" to change it under a much lower interval. if you read what they call "sever conditions" it's what most car buyers do with there cars everyday. imo, oil changes need to be done atleast every 6 months regardless of mileage. every 3k miles to an oil change is definetly overkill these days even with dino oil. i would go 3,500-4,000 on dino oil and 4,000-5,000 on synthetic and change your oil filter every time.
Old Dec 9, 2004 | 06:09 AM
-Bionic-'s Avatar
Former Sponsor
So you get the filter from the Honda dealer? Last time I went there they replaced all Honda filters with a small oil filter that wouldn't even fit in a lawnmower.
EDIT: I did some research and it seems that the code for the Toyo Roki S2000 oil filter is 15400-PCX-004. Now, where do I get them for a good deal? Ebay and google doesn't really help.
Modified by -Bionic- at 3:26 PM 12/9/2004
Old Dec 9, 2004 | 06:57 AM
Filthy Focker!'s Avatar
Default Re: (KGAccord)
I do mine, on a 2002, around every 10,000 km.
The oil we can purchase now is much better quality than what our dads used to use back in the day. So it is assumable that the oil will last alot longer. I do not find a problem with this at all.
fs
Old Dec 9, 2004 | 07:21 AM
b18crx's Avatar
try mobile 1. you'll never go back to conventional oils. change every 10-12k.
Old Dec 9, 2004 | 08:11 AM
Default Re: Oil and filter change intervals on a 2004 Accord (b18crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18crx &raquo;</TD></TR><TR><TD CLASS="quote">try mobile 1. you'll never go back to conventional oils. change every 10-12k.</TD></TR></TABLE>
10-12K??
send some 10-12K used mobil 1 to blackstone labs and see if they think that is acceptable.
Old Dec 9, 2004 | 08:44 AM
KGAccord's Avatar
i feel bad for your car's engine
Old Dec 9, 2004 | 06:51 PM
alotawatts's Avatar
I'm in line with KGAccord. Every 4-5k with filter - all my vehicles.
10 -12k miles ? The oil must look like ink ? And be about as thin !
Old Dec 9, 2004 | 08:49 PM
C_H_A_D's Avatar
Default Re: Oil and filter change intervals on a 2004 Accord (alotawatts)
I change mine every chance I get, Don't see any problem with the normal 3K
yeah oil additives suck, seafoam is all I need
Old Dec 9, 2004 | 09:03 PM
sj993's Avatar
Default Re: Oil and filter change intervals on a 2004 Accord (mood513doom)
Just because you use Mobil1 doesn't mean you should wait for your car to die before changing the oil. I'd say change it every 5K at most, no more.
Old Dec 9, 2004 | 09:09 PM
tsdenny's Avatar
15400-PCX-004 is that part number for s2k filter? im been changing my oil every since i had the car .. and always used fram.. i heard the s2k filter is better built from a friend. so i guess ill give it a try.
Old Dec 10, 2004 | 06:35 AM
pnut's Avatar
Default Re: Oil and filter change intervals on a 2004 Accord (01silvercord)
yes, that is the s2k oil filter part number.
yes it is better designed for that vehicle than any aftermarket oil filter.
if anyone wants a discount on buying bulk amounts of oil filters and live in ATL, GA .
South Honda
6871 Mt Zion Blvd
Morrow, GA 30260
1-800-NEW-HONDA ext 3026 ask for John Planer
min of 30 oil filters for discount. call for price
