JDM itr steering wheel (non srs) in ek?
Old Nov 28, 2004 | 07:02 AM
SpoonmeSami's Avatar
Default JDM itr steering wheel (non srs) in ek?
I have a 99 coupe and i was looking to buy this steering wheel off another member. So will a JDM itr Steering wheel (non srs) fit in my ek with no problems? If so is it difficult to install? Any help would be greatly appreaciated
nm i just searched it and it said i need a ctr wheel or a teg steering wheel column
Does anyone know if i can simply buy a momo hub and it'll work?
Modified by SpoonmeSami at 9:33 AM 11/28/2004
Old Nov 28, 2004 | 08:16 AM
turboxsi's Avatar
Default Re: JDM itr steering wheel (non srs) in ek? (SpoonmeSami)
Why do you want this so bad, JDM Y0!! Plus cars that have had airbags, but are removed, i believe is grounds for not passing a car in safety inspection. just my 2 cents.
Old Nov 28, 2004 | 08:18 AM
Default Re: JDM itr steering wheel (turboxsi)
lol.....no not because its jdm because i dont like my stock huge one
Anyway thanks for your help guy
Old Nov 28, 2004 | 08:26 AM
turboxsi's Avatar
Default Re: JDM itr steering wheel (SpoonmeSami)
Then why not buy aftermarket momo, spoon, mugen steering wheel w/ SRS a simple bolt, rather then changing out your whole steering column (which all together would cost more)
Old Nov 28, 2004 | 08:28 AM
Myh4tch's Avatar
i would have to concure, simply I do not think that the ITR wheel fits, and it is 50% that I am wrong...
but to add a little food for thought, depending on how much you are going to be spending on this jdm y0 toy, I think you should put the money into a different wheel such as momo or sparco...
Old Nov 28, 2004 | 08:31 AM
well if i had to change out my steering wheel column i wasn't gonna get it. I was looking into the mugen type steering wheel with a momo hub, but i liked the oem look of the ctr/itr one's better so i was cheaking if it would fit with a momo hub. but i guess not. I guess i'll keep searching for a ctr one. Any of you guys know if the mugen "sports type steering wheel" -actual name... will fit a honda horn button
Old Nov 28, 2004 | 09:10 AM
fishnfst's Avatar
You can do a CTR, usdm S2000, jdm dc5, and a insight wheel all bolt up to your existing steering wheel column and the airbag will function as well...
Old Nov 28, 2004 | 02:23 PM
TurboTagTeam's Avatar
If they werent 400$ id say go with the ek type r wheel. They look stock witch is better than an aftermarket one.
Old Nov 28, 2004 | 03:10 PM
Default Re: JDM itr steering wheel (TurboTagTeam)
Yup thats what i was thinking
Old Sep 5, 2005 | 04:28 PM
CHiNkStEr's Avatar
Default Re: (fishnfst)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fishnfst &raquo;</TD></TR><TR><TD CLASS="quote">You can do a CTR, usdm S2000, jdm dc5, and a insight wheel all bolt up to your existing steering wheel column and the airbag will function as well...</TD></TR></TABLE>
also usdm dc5 rsx and usdm ep3 civic si will fit also
BlueIntegraBoy
May 22, 2003 01:45 PM
jonas
May 14, 2003 11:59 AM
Realhp.com
Apr 28, 2003 09:17 PM
ckkl
Mar 1, 2002 02:28 AM
