Broke off breather valve nipple, what should i do??
This sounds really stupid, but I broke off the breather nipple on the valve cover. I had some ghetto tubing on it for a catch can setup and I couldn't get the clip off the line and I started hammering and one thing led to another....now the nipple is broken off. Is this a job for JB weld? Or do you think I should get a new valve cover? It's just a vacuum fitting so it shouldn't be that big of a problem...just wanted your opinions
You could prolly "Jerry RIG" something-- try tapping some threads in the hole, then Fix something up that will work.
But I wouldnt just Jb Weld it to the broken edge. If you are gonna JB Weld it, I would drill the hole out, until what you have left of the Nipple will slide down in the freshly drilled hole. Then put some JB Weld around it.
Hope this helps
.Hope this helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stareatsun »</TD></TR><TR><TD CLASS="quote">step one: go to the junkyard
step two: get a new valve cover off a dead car
step three: spend $25
step four: install</TD></TR></TABLE>
step five: dont hammer it again dumb nuts
