ACI: Rear Lower Tie Bars and Trunk Braces - New Lower Prices and Free Shipping!
Advanced Chassis Innovations
Advanced Chassis Innovations offers chassis reinforcement products for Honda and Acura applications.
Our bars and braces utilize aircraft-quality T6-6061 solid aluminum bars that are both lightweight and extremely rigid. Compared to hollow aluminum tubing, common to many other manufacturers, solid aluminum offers a far superior strength/weight ratio.
Additionally, we include extremely strong Grade 10.9 or equivalent hardware and high-quality rod ends. When ordering, you can choose between a high-gloss red or black powder coated finish that not only looks stunning, but is also much more durable than paint.
The majority of our products are bolt-in installations with no drilling required.
Photos:
Finish Options: http://chassisinnovations.com/34.php
Various Hardware: http://chassisinnovations.com/37.php
The following represents our current product line, which will be updated in the near future with additional products and applications.
Rear Lower Tie Bars: $68
94-01 Integra
90-93 Integra
92-95 Civic
93-97 del Sol
88-91 Civic/CRX
Our Rear Lower Tie Bar connects the rear control arms, effectively reducing chassis flex and improving both handling and steering response. This is a simple bolt-in installation with no drilling required.
Current applications include the 94-01 Acura Integra, 90-93 Integra, 92-95 Honda Civic, 93-97 Honda del Sol, and 88-91 Civic/CRX.
Our rear lower tie bar is compatible with the stock swaybar, Integra Type-R swaybar, as well as aftermarket sway bars. Additionally, our hardware allows the tie bar to clear the BSQ, Beaks, or other subframe reinforcement kits if necessary.
-7/8" Solid Aluminum Bars (aircraft-quality T6-6061) with red or black powder-coated finish
-Grade 10.9 or equivalent hardware and high-quality rod ends
-Weighs less than 2.5 lbs
-Simple bolt-in installation; no drilling required
Photos:
http://chassisinnovations.com/25.php
Floor Trunk Brace: $68
94-01 Integra
92-00 Civic
93-97 del Sol
Our Floor Trunk Brace connects two points of the trunk floor, utilizing factory tapped holes in order to effectively reduce chassis flex and improve handling and steering response. This is a simple bolt-in installation with no drilling required.
Current applications include the 94-01 Acura Integra, 92-00 Honda Civic and 93-97 Honda del Sol.
-7/8" Solid Aluminum Bars (aircraft quality T6-6061) with red or black powder-coated finish
-No drilling required
Photos:
http://chassisinnovations.com/29.php
Rear Trunk Brace: $59
94-01 Integra 2dr except Type-R
Our Rear Trunk Brace connects two points of the trunk wall, improving upon the brace found stock on the USDM Integra Type-R. Drilling is required for installation.
Current applications include the 94-01 Acura Integra (2dr except Type-R).
-Drilling required for installation
Photos:
http://chassisinnovations.com/32.php
Stage 1 Kit: $119
94-01 Integra
92-95 Honda Civic
-Includes Rear Lower Tie Bar and Floor Trunk Brace
Stage 2 Kit: $159
94-01 Integra (except Type-R)
-Includes Rear Lower Tie Bar, Floor Trunk Brace, and Rear Trunk Brace
All parts can be ordered from http://chassisinnovations.com/products.php
We are PayPal verified and ship via USPS Priority w/ Delivery Confirmation.
Each order will arrive within 2-3 business days and will include all hardware required for installation, as well as a detailed installation guide.
Modified by ChassisInnovations at 10:34 AM 1/9/2005
Photos:
94-01 Integra
90-93 Integra
92-95 Civic
93-97 del Sol
88-91 Civic/CRX
Photos:
94-01 Integra
92-00 Civic
93-97 del Sol
Photos:
Photos:
Stage 1 Kit: $119
94-01 Integra
92-95 Honda Civic
Stage 2 Kit: $159
We're actually going to be doing some EF test fitting shortly. We'll be sure to update the topic once we have products available for that application!
We should have EF listings within a week, as we have lined up a test car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELAMINT5 »</TD></TR><TR><TD CLASS="quote">no EF CRX products?</TD></TR></TABLE>
EF test fitting this weekend, EF releases soon to follow!
We have completed EF test fitting and taken the measurements. Rear lower Tie bars are now available for EF applications. Trunk braces however would require drilling for EF, and therefore will not be offered. If anyone wants to take on the install with drilling for the trunk brace, we will be glad to supply them! More applications to come!
Also, our C-pillar offering should be on the market soon. R&D currently in progress... we are always working on a new product!
Modified by ChassisInnovations at 11:09 AM 12/13/2004
recieved product a couple of weeks ago...got it very fast and only took an hour ( in the rain ) to put it on...FYI for future purchasers...a torque wrench will help you in the install
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diversegsr »</TD></TR><TR><TD CLASS="quote">bump...I'll try to get one up soon</TD></TR></TABLE>
allright, thanks.
allright, thanks.
Could you direct me to somewhere I can see what the 'Beaks Kit' is?
I have never heard of it before but I was wanting to order your Stage 1 kit for my 93 Civic hatch.
Do you have any other pics of how the lower tie bar attaches to the control arm? I have Suspension Techniques sway bars and their bracket has prevented me from installing a lower tie bar up until I saw your part.
xrdriver,
the beaks kit is a subframe reinforcement kit for those that have upgraded their rear anti-sway bars.
You can see it here:
http://beaksproducts.com/SRK_E...t.htm
Our tie bar with the extra beaks kit hardware will allow the proper clearence you need with the suspension techniques rear bar and hardware. We have had fitments on cars with this bar already.
Our Rear Lower Tie Bar connects the rear control arms bolts, seen here with a 22mm Integra Type R rear sway bar and Beaks kit installed:
http://www.chassisinnovations.com/27.php
Just to let you know, we have a holiday special valid until tonight at midnight with some very enticing prices, see the post here:
https://honda-tech.com/zerothread?id=1094109
Soooo...
I just ordered the stage 1 kit but I completely forgot to specify what I was ordering
I want the black lower tie bar and a red trunk brace for a 92-95 Civic hatch.
Cheers!
Cheers!
Hey everyone,
Just a reminder that our free shipping (USPS priority 2-3 day) sale is scheduled to end at midnight on dec 31st, so hurry and save!
