D15b swap done check engine light help!!!???
Old Nov 27, 2004 | 10:37 PM
PhatwhipsJDMkits's Avatar
Default D15b swap done check engine light help!!!???
Ok swapped a d15b into my 89 crx si. Changed to the correct P08 ecu. Now before with the stock motor and ecu the check engine light would come on after the car was hot and youd get on it. Well i drove the car with the swap for about 30 miles id say got on it and it came on again. It goes off after the cars turned off but as soon as you get on it the light comes back on. Before with the stock setup i thought it was an O2 sensor but now it has different O2 engine and ECU but seems to be the same problem. Car runs fine vtec still works doesnt seem to be any power loss. Anyone PLEASE???
Old Nov 28, 2004 | 03:46 PM
hatchi's Avatar
Default Re: D15b swap done check engine light help!!!??? (PhatwhipsJDMkits)
what code is it popping up??
Phshorty
May 19, 2007 09:34 AM
ef8-dc2619
Jan 31, 2007 04:29 PM
PhatwhipsJDMkits
Nov 28, 2004 09:31 AM
PhatwhipsJDMkits
Nov 27, 2004 11:47 PM
luvinmyGSR
Aug 26, 2004 08:27 PM
