cooling fans wont turn off
Old Nov 27, 2004 | 09:54 PM
Mrob91GS's Avatar
Default cooling fans wont turn off
sup errbody
im havin a problem with my cooling fans. wel i guess it is actually just one of them (the primary one, not the one that kicks on with the AC) when i turn the car off and remove the key from the ignition the fan will turn on, sometimes right away, sometimes within 10 mins or so. When i turn the key back into the run postion, the fan will turn off, and then usually it will stay off when i take the key out after doing this. not a big deal, but a pain in the *** nonetheless as it will drain my battery if im not around to watch and see if the cooling fan turns on or not.. what is wrong? is it the switch, maybe a relay? please resond with any ideas thanks again
Old Nov 27, 2004 | 10:43 PM
brandnewman16's Avatar
Default Re: cooling fans wont turn off (Mrob91GS)
mine did this too far a while after my swap, i just ran a postive/negative wire to a toggle switch n my car and turned it on when i was in the car and switched it off when i got out... turns out it was a themrostat prob and i fixed it
Old Nov 28, 2004 | 02:03 AM
Stripped Honda's Avatar
99-0104
Default Re: cooling fans wont turn off (brandnewman16)
most likely it is a bad fan switch but while your at it change the thermostat just for good measure .... does the car overheat ?
Old Nov 28, 2004 | 07:57 AM
Mrob91GS's Avatar
no the car doesnt overheat or nething like that the fans just run randomly when the key is out of the ignition lol... ill look into the fan switch/thermostat thanks
Old Nov 28, 2004 | 08:03 AM
hOndafienD 04's Avatar
either A) fan switch or B)thermostat......the switch is the most expensive so i'd do the thermostat 1st.
Old Nov 28, 2004 | 06:16 PM
Mrob91GS's Avatar
where is the thermostat located on the motor? likewise with the fanswitch? thanks
Old Nov 28, 2004 | 06:21 PM
the g2 teg's Avatar
i think its just a g2 teg thing ive had 2 g2's and they both have done that theres a sticker on the rad support and it say will run for 10-12 minutes
Old Nov 28, 2004 | 07:12 PM
Mrob91GS's Avatar
hmm ill have to look into that never thought to look... thanks
s13hero
32
Jun 8, 2010 04:42 AM
jdragon1974
May 20, 2010 08:24 AM
snowman2876
10
May 14, 2010 10:20 AM
kai-chun
12
Sep 8, 2006 03:20 PM
wsiracerz
50
Jun 10, 2004 12:09 PM
