HELP PLEASE!!! MY MECHANIC'S BOGGLED!!!
Old Nov 27, 2004 | 08:33 PM
pr0jektdc2's Avatar
Default HELP PLEASE!!! MY MECHANIC'S BOGGLED!!!
sorry for making a second post guys but i dont have my comp. right now so i have to use my friends and i need help asap so please bare [sp?] with me...
well in my previous post i mentioned my car wouldnt start after an engine wash. my mechanic just swapped out the ICM and got spark in all four cyl. but now after 2 hours the spark seems to be getting weaker even with a charger hooked up the voltage begins to fade....and as of right now the car still will not start...we were pretty sure it was the ICM because my original ICM had shown readings way above stock spec.
one last note the wire from the engine fuse box to the alternator [+] was burnt...could this be preventing my car from starting... please help me out!! TIA!!!
P.S. so far i have changed out my plugs,wires,cap and rotor....
Old Nov 28, 2004 | 06:40 AM
Chiovnidca's Avatar
Default Re: HELP PLEASE!!! MY MECHANIC'S BOGGLED!!! (pr0jektdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pr0jektdc2 &raquo;</TD></TR><TR><TD CLASS="quote">
one last note the wire from the engine fuse box to the alternator [+] was burnt...</TD></TR></TABLE>
That would be a good place to start. Check your fuses too.
Old Nov 28, 2004 | 06:52 AM
The Toecutter's Avatar
Default Re: HELP PLEASE!!! MY MECHANIC'S BOGGLED!!! (Chiovnidca)
I agree. check fuses
Old Nov 28, 2004 | 10:33 AM
PrettyLude's Avatar
check the big fuse for the battery, its very easily over look those big square fuses
Old Nov 28, 2004 | 03:22 PM
v4lu3s's Avatar
RTFM
chek all wiring for shorts and burnt areas, anyplace that is burnet needs to be repaired or repalced.
cksnah252
Sep 20, 2015 08:28 AM
(808)b20v-t-eg6
Jan 17, 2012 05:31 AM
THE GAME IS THICK
Jun 25, 2007 04:40 PM
pr0jektdc2
Nov 28, 2004 05:39 PM
