Does anyone use a lighted crank pulley?
Old Nov 27, 2004 | 05:45 PM
JDMJONES's Avatar
Default Does anyone use a light weight crank pulley?
Is this a good idea or is it a waste for turbo applications?
Modified by JDMJONES at 3:01 AM 11/28/2004
Old Nov 27, 2004 | 05:48 PM
earl's Avatar
Default Re: Does anyone use a lighted crank pulley? (JDMJONES)
What do you need the light for?
Old Nov 27, 2004 | 05:49 PM
RenoRacing's Avatar
Default Re: Does anyone use a lighted crank pulley? (earl)
so it matches his wheels with the firefly thingy's when he's rollin' duh
Old Nov 27, 2004 | 05:59 PM
JDMJONES's Avatar
Default Re: Does anyone use a lighted crank pulley? (RenoRacing)
Lighted. HA HA. Jokes on me.
Old Nov 27, 2004 | 06:07 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMJONES &raquo;</TD></TR><TR><TD CLASS="quote">Lighted. HA HA. Jokes on me. </TD></TR></TABLE>
It sure is . I run OEM btw.
Phil
Old Nov 27, 2004 | 06:12 PM
JDMJONES's Avatar
Default Re: Does anyone use a lighted crank pulley? (hondaguyef)
I don't have a Flame Suit or a dictionary. Should I get one for the future?
Old Nov 27, 2004 | 06:15 PM
JDMs1eeper's Avatar
all the small things add up... to still a small thing haha
Old Nov 27, 2004 | 06:18 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMJONES &raquo;</TD></TR><TR><TD CLASS="quote">I don't have a Flame Suit or a dictionary. Should I get one for the future? </TD></TR></TABLE>
Yes you should. A mod was the first person to flame! Ouch!
Old Nov 27, 2004 | 06:22 PM
JDMJONES's Avatar
So, back to the topic. Keeping my stock crank pulley is a good idea.
Old Nov 27, 2004 | 06:40 PM
JDMs1eeper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMJONES &raquo;</TD></TR><TR><TD CLASS="quote">So, back to the topic. Keeping my stock crank pulley is a good idea.</TD></TR></TABLE>
If you havent already baught the crank pully, then leave it stock and use the money towards something that will help you out a lil better. like tunning or something that'll have greater benifits. A pully is something an N/A guru would get because they need to squeeze as much as possible out of their motors. On boost you just tune and up the boost until you are at your goal or limit.
Old Nov 27, 2004 | 06:52 PM
hondaguyef's Avatar
Yes it is
Old Nov 27, 2004 | 06:55 PM
J337_UNIT's Avatar
I have an unorthodox crank pulley.. its light as hell.. ive had it for about 15-20k miles... didnt really seem to make much of a difference.
Old Nov 27, 2004 | 06:59 PM
zcsol93's Avatar
Default Re: Does anyone use a lighted crank pulley? (J337_UNIT)
good way to spin a bearing if u got lighten fly also...
Old Nov 27, 2004 | 07:05 PM
JDMJONES's Avatar
Default Re: Does anyone use a lighted crank pulley? (zcsol93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zcsol93 &raquo;</TD></TR><TR><TD CLASS="quote">good way to spin a bearing if u got lighten fly also...</TD></TR></TABLE>
Really?
Old Nov 27, 2004 | 07:17 PM
JDMs1eeper's Avatar
Really? </TD></TR></TABLE>
I would think because its so damn easy to over rev the engine w/ one.
I went from a stock GSR flywheel to a 8lb flywheel on my b20 turbo. It didnt help performance much at all, shifting seems to be differnt. You have to flatfoot shift when raceing or your RPMs will drop you outta boost easy with a bigger turbo. Id rather spend the money else where unless i had money to waist haha... my .02 cents
Old Nov 27, 2004 | 08:10 PM
Dngerzone2's Avatar
Default Re: Does anyone use a light weight crank pulley? (JDMJONES)
I was thinking about gettting one Tom@camp1320.com said they work great for turbo cars. The OEM N1 CTR pulley. anyone have any input with the CTR N1 factory pulley its stock right.??
Old Nov 27, 2004 | 08:32 PM
mattcalica's Avatar
i've read about lightend pulleys ******* up oil pumps because they dont have harmonic dampeners. I would recommend the ctr pulley because its light and it comes with the dampener, so you dont gotta worry about oil pump failure and such.
Old Nov 28, 2004 | 07:22 AM
Civic_95_Si's Avatar
Default Re:
I've had my UR crank pully for about two years now w/o any problems.
Old Nov 28, 2004 | 07:31 AM
alpha's Avatar
&lt;Sarcasm&gt;I really like this Fluidampr pulley thing Arturbo is selling. Might just be hype I dont think it works too good but it looks ok.&lt;/Sarcasm&gt;
Old Nov 28, 2004 | 07:52 AM
JDMJONES's Avatar
Default Re: Does anyone use a light weight crank pulley? (0x64)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">&lt;Sarcasm&gt;I really like this Fluidampr pulley thing Arturbo is selling. Might just be hype I dont think it works too good but it looks ok.&lt;/Sarcasm&gt;
That's pretty cool looking. Looks kind of like a land mine.
Old Nov 28, 2004 | 07:58 AM
alpha's Avatar
That's pretty cool looking. Looks kind of like a land mine. </TD></TR></TABLE>
Might save me from a land mine
From Fluidampr ...
"The inertia ring inside Fluidampr shears through a thin film of highly viscous silicone fluid to effectively control harmonic vibration at all engine speeds. But what is silicone fluid really like? Well, fluid is somewhat of a misnomer because it is really more like a gel. The silicone fluid used in Fluidampr is clear in color and is more than 45,000 times thicker (more viscous) than 30 weight motor oil.
Silicone fluid is a very good damping medium because it is relatively unaffected by temperature changes. Thus, it provides consistent damping in both winter and summer. The fluid does not harden or change viscosity if Fluidampr is not used for a period of time. The fluid is so durable that big rig, 18 wheeler truck engines are mostly all equipped with viscous fluid-type dampers.
Silicone fluid's damping capability is unmatched. That's why the fluid inside Fluidampr is guaranteed for as long as you own it."
Old Nov 28, 2004 | 08:11 AM
m R g S r's Avatar
I have a fluidamper going onto my built motor. On my stock block I just left the stock pulley, and I'm not revving much higher than stock (8500rpm's)
Old Nov 28, 2004 | 08:30 AM
J337_UNIT's Avatar
Default Re: Does anyone use a light weight crank pulley? (m R g S r)
honda motors are pretty damn well balanced internally .. i dont know why people are knocking the lightened pulleys especially when there are 100's of people on here with them who have never had a problem. find me a thread or 2 which says they had a serious motor problem DUE to having a lightened pulley..
Old Nov 28, 2004 | 09:50 AM
Boosted Chemist's Avatar
Default Re: Does anyone use a light weight crank pulley? (J337_UNIT)
i went with the CTR n1 pulley, cheep and affective
JDMDC2899
Aug 7, 2008 09:09 PM
tsjeff
Northern California (Sales)
19
Apr 10, 2007 08:51 AM
efinitup
10
Dec 13, 2006 01:01 PM
fizic
Jul 4, 2005 02:35 PM
duececoupe2
Feb 28, 2005 08:04 PM
