removing oxidation
Old Nov 27, 2004 | 05:34 PM
deviant1's Avatar
Default removing oxidation
Is there any way to remove oxidation from the clear coat or paint? The white splotch near my roof is growing and it looks plain nasty on a black car. I tried Meguiars paint cleaner and some wax and didn't have much results. Would wet sanding help? Or would wet sanding totally eliminate my clear coat and it wouldn't shine anymore? I've heard turtle wax makes a heavy duty rubbing compound but I'm hesitant on using it. Anyone got experience with this? Even before and after pics?
Old Nov 27, 2004 | 07:23 PM
FredoTheChimp's Avatar
Default Re: removing oxidation (deviant1)
Sanding and some polish may improve how it looks, but it will still be dull as hell, and may and probably will look worse.. Theres really no way to correct it once it's reached the point where the clear coat has started to peel away aside from respraying the area.
If the rest of your paint is good maybe try getting the roof resprayed, but usually when this is the case the rest of the paint is pretty tarnished.
Modified by FredoTheChimp at 4:36 AM 11/28/2004
Old Nov 27, 2004 | 07:27 PM
swanny's Avatar
Default Re: removing oxidation (FredoTheChimp)
snap a pic of it,
Old Nov 28, 2004 | 01:29 AM
plusONE jboy's Avatar
yeah i have that on my roof also.. it has got so bad that i gave up untill a new paint job..
Old Nov 28, 2004 | 02:36 AM
B U N M A N G O's Avatar
sounds to me like you're experiencing clear coat failure
Old Nov 28, 2004 | 04:01 AM
Ya@inlinePRO's Avatar
repaint it
Old Nov 28, 2004 | 04:07 AM
AdReNaLiN's Avatar
clay bar
Old Nov 28, 2004 | 04:20 AM
deviant1's Avatar
Default Re: (AdReNaLiN)
I've heard about claybaring it but I'm not sure if it would remove the white.
Old Nov 28, 2004 | 07:11 AM
GoobDetailer's Avatar
Default Re: (deviant1)
It won't. It would be good for the whole car if it has never been done (to remove contamination--the stuff that you can feel, the grittyness) but it isn't going to touch oxidation.
You can try Meguiars ColorX. It should help, depending on how bad it is, you may have to bump up to something stronger.
If it is in "splotches" then this may be clear coat failure and for that, there is nothing you can do short of repainting.
eoris__ej1
Paint and Body
Jan 10, 2010 03:04 PM
Joe-G
Paint and Body
Jan 29, 2008 08:11 PM
djtony5
Welding / Fabrication
16
Feb 7, 2007 11:49 AM
AF-b16a1
66
Jan 7, 2005 03:34 PM
internet ay
Nov 25, 2001 05:27 PM
