power steering is acting weird
Old Nov 27, 2004 | 05:32 PM
Ls InTeGrA RaCeR's Avatar
Default power steering is acting weird
ok here's the situation....I just put a new powersteering pump on my Integra and it was working fine for about 70 miles and now its acting strange. Its kinda tuff to steer (like have almost no powersteering). Is this a low power steering fluid thing or is it something else. please help. thanks.
Old Nov 27, 2004 | 05:56 PM
53JDMDC2's Avatar
Default Re: power steering is acting weird (Ls InTeGrA RaCeR)
is there still fluid in the resavoir?
Old Nov 27, 2004 | 06:00 PM
Default Re: power steering is acting weird (53DC2)
yeah, its reading between high and low.
Old Nov 27, 2004 | 06:36 PM
Cory man's Avatar
Did you bleed the system when you finished your pump install?
Old Nov 27, 2004 | 06:39 PM
Default Re: power steering is acting weird (Cory man)
by bleed the system do you mean remove powersteering fluid from the reservor and replace it? if not....how do you bleed it?
Old Nov 27, 2004 | 07:35 PM
Old Nov 27, 2004 | 07:42 PM
blacknbean's Avatar
from my memory the haynes manual says, turn the steering wheel all the way to the left then right a few times to relieve any air in the system, then recheck the fluid level
Old Nov 27, 2004 | 08:04 PM
Cory man's Avatar
Default Re: power steering is acting weird (blacknbean)
Just like what was said above. Turn the wheel lock to lock several times and check the fluid level afterward. If you have air in the lines it may give you a sort of "choppy" feel through the wheel when turning. HTH
Old Nov 28, 2004 | 04:10 PM
ok now the powersteering is doing something new. It moves with ease then it tightens up, moves with ease and tightens up. What the hell is going on! Its a brand new Pump!
Old Nov 28, 2004 | 05:18 PM
Cory man's Avatar
Did you bleed the system yet? The symptoms you describe sound like air in the lines. You need to bleed it several times until you dont see any air bubbles in the reservoir.
Old Nov 28, 2004 | 07:33 PM
I've turned the darn wheel back in forth about 40 times and its still acting the same way?????
theineffable
Honda Civic (2001 - 2005)
28
Sep 25, 2012 08:30 PM
tt3
Oct 6, 2011 04:43 PM
91_accordwagon
Jan 30, 2011 07:48 PM
tegh22
May 12, 2008 12:09 PM
JBirch_97Prelude
Dec 6, 2007 07:53 PM
