engine help
I need some suggestions about this motor. I'm working on my friends 87 crx the old carbureted motor. His dad replaced all the little things like: spark plugs, spark plug wires, Distributor cap and the pcv filter. The motor will crank but won't fire up. I just need some more suggestions of what i should do. thanks
It's been a while since i played with a carbed honda motor. Check the external coil (5th wire on dizzy cap) and the ignition module (inside dizzy). Are the two fuel filters clean?
Those motors used a mechanical fuel pump on the engine. Sometimes the diaphrams would dry up, making it not pump. They are cheap and worth a shot if you're not getting fuel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 »</TD></TR><TR><TD CLASS="quote">Those motors used a mechanical fuel pump on the engine. Sometimes the diaphrams would dry up, making it not pump. They are cheap and worth a shot if you're not getting fuel.</TD></TR></TABLE> he beat me too it
purplexs650d
Oct 17, 2006 12:31 PM
mykem
Dec 1, 2003 05:54 PM
